Question about GE Dryers
GE washer squeaking
I have a GE Profile Sensor Dryer(model DPSQ495ET0WW) That I replaced the belt and tensioner are pully. now it squeaks like crazy once it starts to heat up. any ideas?
  • Brad Hester
    Brad Hester Jul 27, 2010
    Arm pulley thats is :)
    Problem Solver:
  • 16 Answers
Make sure the felt on the rim of the drum is secure and the plastic glides that the drum sits on are not worn down.
Posted on Jul 28, 2010
Has a bad squeaking noise. Replaced alternator, belt and pully. Still squeaking
bad crank pully, check to see if the lower main pulley is wobbley or the belt tensioner
Oct 11, 2012 | Chevrolet Silverado Cars & Trucks
My ge profile dryer sarted squeaking whats the possible cause
The drum rides on two rubber rollers with nylon or plastic centers which become worn over time. You can access the rollers by removing the front lower cabinet under the door. Other points to check are the tension pulley which provides tension on the belt which you can access from the removed lower panel. The cabinet has a felt ring as a spacer preventing the drum from rubbing against the cabinet which may have fallen or become worn, which is rare. If you still have not found the cause you can attempt to run the motor without the belt to eliminate squeaking from the motor.
Feb 24, 2011 | GE Dryers
GE dryer, model DBXR453EVOWW - squeaks at start up
It could be the rear drum bearing, or the belt needs replacement.
Aug 28, 2009 | GE DBXR453EV Dryer
My series 80 dryer squeaks
do not lubricate anything in a dryer you will damage .locate the the squeek if it is coming from the rear of the unit most likly need to replace the drum support or wheels if its intermittant and has a squeek squeeek noise that either gets worse or goes away when the dryer heats up the tensioner pully or the moter berrings are bad
Aug 10, 2009 | Dryers
Squeaks alot when it is drying clothes, my husband replaced the belt, and front felt. what could it be?
Replace the tensioner roller assembly that tensions the belt. also, check the rear drum rollers that the drum rests on for free spinning but no wobble or noises, If loose or wobbly, replace them too.
Aug 04, 2009 | GE Profile DPSB620GCWW Gas Dryer
GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
May 17, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge profile dpsq495et0ww has a severe squeak to it. we checked out if it was the belt. and the belt looks good. when we take off the front door it doesn't squeak when we turn it on but if i manually turn it...
The problem could probably be with the drum bearings or the drum support rollers. The following link direct you to the internal diagrams of this dryer model with the part selection in case of any damaged parts. Hope that helps you out.
Dryer internal diagrams
Also will look out for manual and will post in few hours. Please do rate my solution if accepted and also post comments regarding any doubts with the solution provided.Good luck with the machine.
Sunny
Apr 08, 2009 | GE Profile DPSR473EW Dryer
Dryer drum causing squeak
Most likely the front support bearing. If this is the problem you will likely have to replace the slides too. The wizards have a ten year warranty. The bearing is part number WE3M26 and the slides probably need 3 or 4 of them are we1m333. Hope this helps.
Dec 11, 2008 | GE Profile Wizard DPSE592EAWW Electric...
DCXR463GA2WW Squeak
YOU MOST LIKELY HAVE A REAR DRUM BEARING FAILING. IT IS A SMALL TEFLON BEARING THAT SLIPS ON OVER THE REAR SHAFT OF THE DRUM AND INTO THE HOLE IN THE REAR OF THE DRYER. THERE ARE ALSO FRONT GLIDES THAT SUPPORT THE FRONT OF THE DRYER. OLDER DRYERS HAVE THE FRONT SUPPORTS UNDER THE DRUM SO THE DRUM RESTS ON THEM. NEWER G.E. DRYERS HAVE A PLASTIC RING WITH THREE TEFLON GLIDES ON TOP OF THEM AND THE DRUM HANGS FROM THESE GLIDES. REPLACE ALL OR SOME OF THE ABOVE PARTS TO ELIMINATE YOUR SQUEAK.
ON OTHER POSSIBILITY, THE IDLER PULLEY THAT KEEPS TENSION ON THE BELT CAN BECOME A SQUEAK MAKER.
Apr 07, 2008 | GE DCSR483EA Electric Dryer
Dryers Logo
179 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
