Question about Fisher Paykel EcoSmart GWL15
My fisher&paykel washing machine does not work, it looks like it's the fuse, it cost me lots to have someone fix it, but its only the fuse, if someone can help tell me where the fuse is.
  • 11,896 Answers
Follow the power cord, gain access to the inside of rear panel. You will see the fuse attached to the the power board that plugin is attached to.
Posted on Jul 27, 2010
Fisher paykel washing machine fuse smartdrive
All Fisher & Paykel top load washers have 4Amp fuse for 240vac.
Apr 05, 2014 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel washing machine broken start button
Sounds like you've got the nous to fix it. They're a straightforward machine to work on, so have a go.
Here's the service manual for the Fisher & Paykel 503:
http://www.angelsnz.net/ZL3SV/misc/F&P-Washer.pdf
Feb 10, 2014 | Fisher and Paykel Washing Machines
MW512 Fisher & Paykel Washer Machine...Where is the lint filter located?
Fisher & Paykel machines don't have a lint filter.
Manual cleaning of agitator and s/steel bowl will make your washing cleaner.
Oct 12, 2012 | Fisher and Paykel Washing Machines
What is fault code 136 on fisher & paykel gw611 washing machine
first thing to look at is the sensor either faulty or corroded connection block if good or a new one doesnt fix it then most likely the main computerboard fault
Jan 12, 2012 | Fisher and Paykel GWL11 Top Load Washer
Water sensing level not working on Fisher & Paykel Eco Intuitive washing machine . The water just keeps filling up until I stop it manually . We can't use the machine to wash clothes as the Service...
Your pressure value switch is malfunction. First thing you can try that is cheap to fix is to try clean the hose that connects to the outer tub. A lot of times there is algae develops after years of washing.
May 07, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
Cuts the power
hi usually it is the pump that causes most of the problems with these machinesdepending on where youiare these pumps are about $100
cheers grant
Jul 25, 2008 | Fisher Paykel EcoSmart GWL15
Fisher and paykel smart drive 5.0 washing machine.
OK this is kind of an elementary question but have you checked you have power at the outlet?
To do this, plug in a small light or appliance that you know is working. If there is no power then check the supply fuse/circuit breaker. If there is power then the fault is in the machine (duh?).
To find this the circuit has to be checked by someone with the necessary equipment and experience, not something I would suggest an untrained person attempt.
I no this is not a lot of help but the best I can do from here.
Good Luck
Bob
Jan 01, 2008 | Fisher Paykel EcoSmart GWL15
Fisher Paykel EcoSmart GWL15 Logo
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
