Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
It's heavy duty thin twin model. The cycle stops at spin and water stays in the mashine.
  • Whirlpool Master
  • 3,361 Answers
When it gets to the SPIN cycle,wait 45 seconds. If it does not spin,open then close the lid.
If it spins then,replace the timer.
If it does not spin,replace the lid switch.
Posted on Jul 27, 2010
Whirlpool Twin Thin Washer makes very loud noise on drain/spin.
Sounds like the bearing on the drum has gone , open the door and see if you have any play on the drum by moving it side to side and up and down good luck
Dec 13, 2017 | Whirlpool Washing Machines
Kenmore heavy duty 70 series washing machine, water won't stop
sounds like the washer water inlet valve is bad or the water pressure/level switch is bad or clogged or disconnected.  without knowing model hard to diagnose beyond this.
Jul 30, 2010 | Kenmore Washing Machines
After washing heavy load mashine spin cycle not working
Hi just read your posting.Does your machine drain the water .When your machine stopped doing the spin cycle did it start to beep and show a series of lights as an error code?Or have you got the model with the LCD display and it showed an error code in letters?If you have the model with lights and your machine beeped the lights that did come on will be in a row of 8.Starting from left to right is it the 2nd and 5th lights on or the 4th and 8th lights---etc---- that are lit? Please reply and I can help you rectify this fault for you.
Jun 26, 2010 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Westinghouse heavy duty washer
Check this website out. It has a good questions and answers section. I would guess that it is the water inlet valve in the washer, but it could be a few different things.
http://www.repairclinic.com/0088_11_1.asp
I know of a different site that has good prices on parts. I have ordered from them numerous times. Let me know if you need that link.
Oct 03, 2008 | Westinghouse WWS833ES Super Capacity Top...
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
989 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
