Question about Yamaha P2500S Amplifier
No signal on A side, tried all conections, wire to speakers is ok, checked through Bside.
  • Yamaha Master
  • 17,130 Answers
This explains that your output of the side A is not working and it is possible that the output driver would have failed. First of all open the set and check on the fuses. Use a good multimeter to check for the + B voltage in the output drivers. If absent check the power line for break or burn out. If ok then check on the fusible resistors that give the biasing to the drivers. replace if they are Ok but be careful as ther may be high voltages in this section tthat might damage the circuit if shorted. if you find the outputs draing in more or less then it must be checked after removal. It is easier to confirm as you have a working side and so replace from the working side or test voltage onthe B side as a comparison to confirm. I hope you try this out. Good day
Posted on Jul 31, 2010
I have a JVC CH-X1100 CD changer in my truck. The sound is only coming out clearly on the driver side speakers....the passenger side speakers sound very low and distorted.
It is only a loose or broken wire to the left speakers. Try at the speaker itself first, and then at the radio. If both of these connections are tight, then check back along the wiring and check that the wiring TO THE RADIO LEFT SPEAKER is OK. If OK, you may have a break in the wire from the radio to the speaker.. It could even be an internal break that is hard to see. The easiest way would be to replace that wire.
Mar 24, 2011 | JVC CH-X1100 12-Disc CD Changer
I have got a Technics SA-AX540 Receiver and (Among other things) a pair of Jamo speakers conected to the receiver. a little whil ago it strated to "act up" in such manor that sound now comme out...
If it acts that way with all sources I would suspect a bad switch contact somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Feb 14, 2011 | Technics SA-AX540 Receiver
My samsung s3310 speaker doesnt work
i have samsung s3310 but has no speaker problem pl solve this
Sep 16, 2010 | Samsung Cell Phones
I have a 2005 chevy malibu and my front driver's side turn signal doesn't work even after trying new bulb...why is that? and how do i fix it?
hi...
check the wiring and connection to the bulb.
check the relay to which the turn signals are been conected.
check the fuse for particular system and if blown out replace it.
Jul 01, 2010 | 2005 Chevrolet Malibu
My speakers arent working, also saying there is no driver installed please help.
Well first of all you ned to see if the speakers are ok y can acheive this by placing two wires onto a 1.5 volt battery and listen for a crackle depending on the conection you might have to tape the wires to the conection to start with on on the bottom of the 3.5 mmjace and one near the top fo the jack around the side dont let them touch otherwise it wont work if you do hear a cracle when you conect the battery then the speakers are working or trry a diffrentset of speakers on youre computer and se what happens
Nov 22, 2009 | Logitech X-530 Computer Speakers
Speakers stopped playing
if the speakers are wired in series, if one goes out the other one wont play either. series is when one wire of first speaker goes into amp, then the other wire of first spkr is connected to one of the wires of second spkr, then the other wire of second spkr goes to the other conection on the amp. kinda like forming a chain. use a 1.5v ( AA, AAA, C-CELL)battery to check your speakers. connect one wire to + side and the other to - side of battery. they should move either in or out. if they move they are still ok. this wont cause them any damage. i use this method all the time to check for spkr polarity.
Oct 21, 2009 | Pioneer 800W Class-D Mono Amplifier With...
Can't get sound off my right speaker,,brand new cartridge, checked wires with VOM everything looks ok but no sound..I'm stuck
Is the amplifer working OK? Go to the phono input and put your finger on the right channel. It should hum. if it does not, you might have lost the internal preamp for cartridges. If it does hum then you need to recheck the right channel wires, conections etc. Don't forget you can change the conections over and see if the left channel will come on the right side.
If it is the preamp you might find an IC is the cause. Often these devices here are static sensetive.
Jul 03, 2009 | Audio Players & Recorders
1999 Mazda B3000 Trailor wire connection, LH signal and brake
Sounds like either a loose connection or a bad ground. I might try re-stripping white (ground) wire and cleaning contact area for the frame conection point. Good luck!!
Jun 10, 2009 | 1999 Mazda B-Series
Low sound on high gain no low gain new tubs
Your power transformer should not be getting hot. The signal is not passing to or through the output transformer.Check the speaker connections on the speaker side of the output transformer. Go to geofex.com and check the tube amp debug page.
Apr 02, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Problem with amp...
In virtually all instances where the protection light is illuminated, the amplifier has gone into protection because the output transistors are shorted. To eliminate external wiring problems do the following.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still goes into protect, the amp likely has blown output transistors.
If it does have blown outputs, it's is likely due to the speaker wires shorting together when the woofer was out of the vehicle.
Dec 29, 2007 | Jensen XA4150 Car Audio Amplifier
Yamaha P2500S Amplifier Logo
63 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
