Question about Sony Televison & Video
Sony KV2649r 26 inch console tv shuts down
I have an older Sony KV2649r 26 inch console television.When you turn it on it will work ok for about 3 minutes.Then it cuts off.If you wait about 5 minutes it will turn on again.I replaced thp-601.The old one was heating up a lot.The new one is not as hot when the set is on but it didn't fix the problem.Any other ideas what is making it cut off?When the inside temperature is low it seems to work ok but when it is warmer inside it cuts off.Thanks.Bill.
SOURCE: T.V WILL NOT STAY ON: JVC AV-27F702 27" TV
This sounds like a protection system cutting in. This happens if there is a major fault and continual use would lead to a fire risk.
Posted on Aug 09, 2007
SOURCE: Samsung DLP TV shuts off
I had the same problem with my Samsung 52" HDLP set turning off by itself. This is a common problem with the Samsung sets and I followed the advice I found online and believed it solved the problem. Remove the lamp cover in the rear of the TV (usually held on by one screw). There is a thermal cut off switch that is activated by the depressing of it by the cover. Factory installation for some reason was not done properly and the switch would not be fully depressed causing the set to shut off.After removing the cover, relace it by seatng the bottom of the cover first to depress the switch and tilting the top of the cover in to close it. Replace the screw &you are done. My set shut itself off for 8 Months before I found this fix. It hasn't shut off since. Good Luck
Posted on Oct 19, 2008
  • 905 Answers
SOURCE: RCA 24V414T KEEPS TURNING OFF
it could be a ghost but most likely a bad solder connection , crystal(controls the eprom)(menu chip) , or the eprom chip itself will need to be replaced
Posted on Dec 01, 2008
ladywinn
  • 5138 Answers
SOURCE: Sony KV36H5500 WEGA TV (flat screen tube) will not turn on
Pull the back Off Disconnect CRT board connected at End of picture tube then turn set on and see if it comes on with volume, high voltage you can feel front of tv for static elect.... Let me know what happens then i can tell you what is wrong with TV.
Posted on Dec 27, 2008
  • 108 Answers
SOURCE: Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Posted on Jan 06, 2009
I have a 26 inch Sony Bravia TV. I just noticed that when I turn to particular channels, the TV freezes. The remote and the buttons on the TV cannot change the station nor turn off the TV.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 07, 2016 | Sony Televison & Video
My tv sony model kdl-32l500 won't turn back on unless I wait about 5 minutes, then tv works fine.
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 13, 2014 | Sony KDL Televison & Video
Audio is OK, Video NO
It sounds by the description that your tv has a defective T-CON (Timing Control) Board -this is evident by the 5 flashes and the fact that the screen was working ok, then going black then repeating.
The board can be bought usually on ebay but, only if you feel comfortable in replacing it yourself, otherwise a sony service tech needs to be called to repair this!
Good Luck
Rich lilja
Dec 15, 2013 | Sony KDL40EX710 40 inch BRAVIA 1080p LCD...
I purchased an Sony Bravia LCD 26 inch of KLV S200A series 3 years back. The LCD has now started developing problems like automatically the power goes off when any particular channel is being viewed and...
You have intermitant problems which may be caused by contact resistance or circuit overheating.After it cooled down the tv starts again. Leave TV on standby at all times.
Jan 03, 2011 | Sony BRAVIA KLV26S200 26 in. LCD TV
I cant get any picture on my sony tv when i connect my ps3 upto it, yet get a picture instantly on a cheap 26 inch hd tv. i'm using a hdmi cable on both
Silly question -- but are you sure your Sony TV is on the correct HDMI channel? My 32 inch LCD has HDMI1, HDMI2, HDMI3. You must make sure you plug the PS3 into the correct HDMI channel and make sure you're tuned into the same one.
Aug 03, 2010 | Sony Playstation 3 (PS3) Console
Red Light is on and when you turn it on it goes off to the red light again
This is related to your power supply which is inside possible one of the 2 fuses inside the power supply has gone bad you can replace those if your ok with opening your unit and little soldering otherwise searcdh ebay for ps3 power supply its a silver box looking dervice about 5 x5 inches. easy to put in takes about 30 minutes start to finsih.
May 02, 2010 | Sony Playstation 3 (PS3) Console
I'm having trouble with Call of duty- Modern warfare 2. Hasn't ever been a problem until today. Once you get on to the main game menu a screen flashes up saying that it has incurred problems registering...
Don' worry. There is a major problem occurring right across the board at this very moment with the PSN Network. Some consoles are not synchronising properly due to an internal clock error and causing problems exactly like you describe. It is expected that Sony will soon have this resolved.
For a full breakdown please look at this FixYa Tip.
If the solution helps, please leave a vote for it. Thanks.
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
, power cuts off ,
the power cable is broke, but not completely thats why come in and out ...
Dec 13, 2009 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
63 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
