Question about Dell A225 2 Speakers
My speakers are not making any sound. i tried pluggin them in and out. checked the sound volume, on the speakers and computer. and still no sound.
  • 3 Answers
I had the same problem, here's what I did:
The LED indicating on / off light is on? If not, connect to another USB port or another computer and test.
If the LED is turning on, make sure that connecting the speakers to another audio you get sound. If you do, then the problem is on your computer, not the speakers. Check the audio
During the above tests, try to twist the cables from the speaker. Maybe one of them is broken, and if you hope to hear sound, one or more cables are malfunctioning. The same goes for the USB cable and the green plug.
If you determine that the cables are the problem and resolve to fix them, this link you will find instructions for opening and closing speakers.
Sorry about the lack of images!
Good luck and hug from Brazil!
Posted on Aug 26, 2010
Volume loss
Laptop or Desktop ?
Try swapping the speakers around to see if the problem is in the speaker itself.
Volume problems on computers often happen for a variety of reasons.
Volume troubleshooting, however, is one of the easiest problems to troubleshoot because there are only a few things that usually cause the problems.
Usually the problem isn't even an error but just merely an adjustment that needs to be made.
Test your speakers.
This is the first thing you should check if you can't hear anything coming out of your computer. First try turning up the volume know and make sure you are in fact turning the volume knob and not a tone or balance knob.
Make sure the speakers are completely plugged in to the wall and the computer. Test with another set of speakers or headphones after you have done this.
Check the computer volume level.
On the taskbar is a volume icon, which usually looks like a small speaker.
Click on the icon and turn the volume up.
Make sure it has not been muted.
Double clicking on the icon will bring up a panel of several volume controls.
Try turning up the volume on each slider.
Go to Control Panel and choose "Sounds and Audio Devices."
Under the volume tab, click speaker volume and turn up the level if needed.
Turn up the application volume. Most programs that use sound have an additional volume control just for that program.
Find the volume control and turn it up.
Usually it is located in the lower right or left corner on the program, but you may have to search for it.
Troubleshoot the sound card.
Download the latest drivers from your sound card manufacturer's website.
Go to Control panel > System > Hardware > Device Manager. Click on "Sound, Video and Game Controllers."
Click on your sound card, select the driver tab and then click on "Update Driver."
Point to the file where you saved the latest drivers from the website.
After this, restart your computer.
The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a can of compressed air or fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
If this doesn't solve your problem, try reseating the sound card into your computer.
Hope this helps
Nov 10, 2012 | Audio Players & Recorders
I cant get the sound to come out of my speakers. I have checked all conection, ect
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 01, 2011 | Logitech LS11 2 Speakers
When we try to plug in the speaker plug it ill not make sound. We checked the Settings and the sound key was on but, when we tryed to play songs no sound came out of the speakers. How do we repair it?
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Jun 05, 2011 | Logitech X-230 Computer Speakers
I unplugged my sound system to re-arrange the living room and when I plugged it all back in it just wouldn't turn on at all. no lights, no nothing. I tried it in 3 different outlets and then in an...
also
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 31, 2011 | Logitech X-540 Computer Speakers
I was given the LS11 speakers and have connected them to my computer. However when I click on the volume icon in the tool bar to ajust the volume it does not work.
also
hope this helps
don
Mar 06, 2011 | Logitech LS11 Speaker 2 Speakers
The speaker system is making a loud rhythmic clicking sound, underneath you can hear the audio at very low volume. The clicking sound does respond to volume control. My drivers are up to date. Don't...
also
hope this helps
don
Mar 03, 2011 | Bose Companion 3 Computer Speakers
I can only listen sound from the 2 front speakers while i have logitech x-530 5.1. My mobo has 3 colours at audio(pink.greeen.blue) and my speakers have green.pink.black. I only plugged green tho. Can i...
plug them all in pink/pink green/green blue/black
hope this helps
Dec 28, 2010 | Logitech X-530 Computer Speakers
No sound my system
If there is no sound coming from your computer try these "simple" but common solutions first.
1. Make sure the power cord is plugged into an outlet and the speakers are turned on.
*Make sure your speakers are correctly connected to the computer.
*Make sure that the speaker cable is plugged into the speakers and the correct jack on the computer.
2. Make sure your computer has a sound card and that it is enabled and working properly:
To open Device Manger...
*Start
*Control Panel
*System and Maintenance
*Device Manager
*Expand the Sound, video and game controllers category.
If a sound card is listed, you have one installed.
*Check the status of the driver and update if necessary.
3. Make sure that the speaker volume is not muted or turned down too low.
To open Volume Control...
*Click the Start button ,
*Click Control Panel
*Click Hardware and Sound
*Under Audio Devices and Sound, click Adjust system volume.
*Under Main Volume, move the slider up or down to raise or lower the volume.
If you still have no sound after checking the solutions above, you more than likely have a bad sound card.
Jul 13, 2010 | Computers & Internet
No sound!!!
Check your computer sound volume. Make sure it is not muted or the volume is set low. Try the speaker into a music player like ipod or mp3 player that will support the speaker jack. See if it works..
Nov 29, 2009 | Dell WL6000 Computer Speakers
Have external gateway speakers
First make sure your sound cards are working properly. 1) Check the master volume of your PC. Go to start menu, control panel, sounds speech and audio devices, sounds and audio devices - i) In volume tab click the speaker volume and check whether all the left, right, etc.. volumes are in medium or high. ii) In audio tab click the volume tab of sound playback and make sure that the master volume is not in mute and all the volumes are either in medium level or at 100%. After making these changes try playing any music. Even if the problem persists go and get your sound card checked in an authorised service centre.
Thanks & Regards,
Shiva
Sep 11, 2009 | HP (ZD929AA) Computer Speakers
Dell A225 2 Speakers Logo
103 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
