Question about Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer
Spin Cycle Fails on Washer
Spin Cycle fails to operate on washer. "Locked Door" light on but washer does not spin clothes leaving clothes dripping wet. Spin cycle fails on each type of wash cycle. "Max Extract" also fails to operate.
  • Anonymous Mar 22, 2014
    washer does not spin fast enough to spin dry clothes
  • Anonymous Mar 30, 2014
    Don't know if finished cycle or mid cycle clothes in washer door locked will not power up
  • 868 Answers
This solution is 100% correct, change the : wax motor &control board.I'll be happy to guide you through this if you need me to.
Posted on May 26, 2008
My maytag washer does not spin fast enough to get the water out of the clothes. Please advise
Randall, the high speed spin failure can be caused by a number of issues. I would suggest starting the machine without any clothes in it. Once it has filled, make sure the door lock light is on and that the door is, in fact, locked. If the light is not on, or if the door is not actually locked, either the door lock assembly or the control panel is at fault.
If the light is on and the door is locked, stop the wash cycle and start a drain and spin cycle to see if all of the water is pumped out of the drum. All water should be pumped out within 10-15 seconds. If excess water is in the drum, the high speed spin will not start.
Mar 06, 2015 | Maytag Washing Machines
Only spins slow
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
May 06, 2009 | Washing Machines
Wet clothes after spin cycle
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
May 05, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore front load washer will not spin. Clothes come out wet.
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Mar 02, 2009 | Kenmore 43142 Front Load Washer
Spin cycle leaves clothes very wet
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Feb 09, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
No Spin Cycle
Your machine won't go into spin cycle most probably because it awaits for pump to start extracting water out of the basket. If the "Door Locked" light is on th an it means that either filter, pump or drain hose are clogged (unless pump burned). Turn off machine, unplug the machine, clean the filter, check for foreign objects inside filter and pump housing and finally check/unclog the drain hose.
Apr 23, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer Logo
697 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
