Question about Denon AVR-3300 Receiver
Hi my denon avr-1800 display not lit and power indicator flashing rapidly i disconet all speaker wiers let cool down and its the same
5 Suggested Answers
SOURCE: Denon AVR 900
well its possible you have it on stereomode put it on prologic ceneter mode on normal for best sound
Posted on Nov 05, 2008
  • 93 Answers
SOURCE: Denon AVR 2807 with Bose Acoustimass 15
Well,i can tell you are not very focus,cause you posted Denon AVR-2807 with Bose AC 15 problem,but under your details,you put down AVR-5807!
First of all,it is so unfortunate that you are NOT able to gain and experience to true ability in sound for this wonderful receiver when you are using a dual tweeters speakers and expect to have good sound separation as a TWO WAY speakers(a tweeter and a midrange-for true high frequency and mid frequency sound separation.)
Secondly,you have defeated the audio configuration of the Denon AVR-2807,since all your speakers are control BY the Bose subwoofer.
Now,i could show you a way to hook this up,and it doesn't matter how you connect them, they are the "bicycle tires" installed with a "Porche"engine if you know what i mean.
If you want a good recommendation for your "beast",i will more than happy to show you the way!
Cheers,
solutiondoct
Posted on Nov 06, 2008
localwonder
  • 6784 Answers
SOURCE: shuts off then red light indicator flashes, disconnected all speakers but still wont work
Hi, this is a power board issue. remove the cover and make sure that this unit doesn't have blow fuse. if the fuse is fine, you will then need to replace the integrated power/ main board.
Posted on May 21, 2009
SOURCE: denon avr 3000 speaker B is off ,is theres a code to turn it on
I have a Denon AVR-3000 and want to turn on the B Speakers. I have hooked up my subwoofer to the B connections on the Denon since there is not a subwoofer connection. How do I turn the B speakers on without a remote
Posted on Oct 06, 2010
I have an avr 4800, and eveytime I raise the volume to -21 or higher it goes into protection mode. can you help? my zipcode is 60184
http://www.retrevo.com/support/Denon-AVR-4800-Receivers-manual/id/363ag816/t/2/
I'd treat this symptom as "DISPLAY not lit and power indicator is flashing rapidly." under Troubleshooting on Page 60.
and I'd evaluate the speaker load you're presenting to make sure it's effectively higher than 6-0hms per speaker channel.
Jan 11, 2011 | Denon AVR-4800 Receiver
AVR-1802 5.1 Channels Receiver: My Denon AVR-1802 LED is flashing rapidly. I have...
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
May 16, 2010 | Denon AVR-1802 Receiver
I have a denon avr 2802. the remote powers the
Try doing a factory reset by turning off main power switch.hold down speaker a and b buttons while turning on main power switch ,display will flash 3 time s then release buttons,this then returns unit to factory default settings.
Apr 13, 2010 | Denon AVR-2802
Denon avr -1709 how do i get it reset to factory specs
SWITCH OFF THE UNIT..PUSH AND HOLD DOWN BOTH SPEAKER A AND SPEAKER B BUTTON WHILE HOLDING DOWN BUTTONS TURN ON MAIN POWER THE DISPLAY WILL FLASH WAIT FOR 3 FLASHES THEN RELEASE. THIS WILL RETURN EVERYTHING BACK TO RFACTORY DEFAULT
Mar 21, 2010 | Denon AVR-1708 Receiver
AVR 684 was working normally then shut off with rapidly flashing red led. Have allowed to cool overnight, tried different power sources, disconnected speakers etc, etc. Any ideas?
The unit more than likely has a fault in the power supply or the output stage. Common switching power supply problems are the FETs used for switching fail or the PWM generator fails. Output circuits can be configured many different ways. The trend these days is to use integrated high power amplifiers for each channel instead of discrete push pull amplifier stages.
Feb 06, 2010 | Denon AVR-684 6.1 Channels Receiver
How do I reset my Denon avr-589? I would like to reset my reciever back to original settings.
Press the power button, and speaker a and speaker b simultaneously and hold until the display begins to flash then release speaker A and speaker B buttons. That resets the microprocessor.
Jan 02, 2010 | Denon AVR-1508 Receiver
Shuts off then red light indicator flashes, disconnected all speakers but still wont work
May 21, 2009 | Denon AVR-1803 Receiver
Denon AVR 2802
if the display did not lit and power indicator is flashing rapidly------you will have short circuit in speakers cables -----turn it off and remove short circuit cable-------or you have block in ventilation holes---------turn power off and leave it to cool down and remove anything block ventilation holes---and turn it on again after cooling---------another solution-------on screen display is set to off on system setup------turn it to on in system setup.
Aug 04, 2008 | Denon AVR-2802
Denon avr-2106 problem!!!
You're drawing too much power from it. Sounds like maybe your sub is hooked up wrong, double check that.
Mar 06, 2008 | Denon AVR-2106 Receiver
Denon AVR-3300 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
