Question about Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer - Blue
Samsung electric dryer
The heat in the dryer is not working but everything else works. How do I figure out what is causing the problem?
    Sergeant:
    Champion:
  • 277 Answers
How old id the system?
If warrenty is over, Open or remove metal covers.
Before you start, unplug your unit.
After you removed panels or opened your unit, on one side should be the element compartment. At the bottom of compartment, is two wires. remove and then take a Ohm meter and check the element. That ok you won't hurt yourself, because you unplugged it.
If you have a reading or the needle moves... your element is fine.
That would mean something else is wrong.. Follow the plug into the unit..
Are the wires burnt, Has one falling off... It needs replacing
Sometime the circuit breaker trips... only half.. so go and reset your breaker and put the dryer back together
Posted on Jul 27, 2010
  • dhadbaoui Oct 28, 2010
    The circuit breaker did the trick. Never would have thought about looking there since it was running fine, just not getting hot anymore all of the sudden. Thanks a bunch!
Kitchenaid gas dryer won't ignite and heat. Everything else seems to work fine -- drum rotates, timer works, just no heat. Model# KGYL517BWH1.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 10, 2011 | KitchenAid Dryers
My dryer doesnt heat. I checked the voltage, and ran through all the diagnostic tests to try to get an error code. Everything works fine when in the test mode. Figuring that all was well i went back to...
heatman101;'
Jul 17, 2011 | Kenmore 84072 Electric Dryer
Kenmore dryer @11064982300 runs but no heat..did all the steps to troubleshoot & everything seems to be working...can't figure out why there is no heat
heatman101
Jul 08, 2011 | Kenmore Dryers
Samsung dryer dv218aeb not heating
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 14, 2011 | Samsung DV218AEW Electric Dryer
Samsung electric dryer model # DV328AEW not heating up to dry clothes
heatman101.,//';
Mar 09, 2011 | Samsung DV448AEE Electric Dryer
Apparently the heat element has gone bad. Everything works, but no heat. It is only about 13 months old, could the heat element have burned out already and if so can a average repairman replace the part....
heatman101
Jan 22, 2011 | Samsung DV218AEW Electric Dryer
My Samsung DV 338AEW, is not heating up, everything seems to be working normal, just no heat.
heatman101
Jan 18, 2011 | Samsung Dryers
Dryer does not heat up. Everything else works fine
heatman101
Nov 02, 2010 | Frigidaire Electric Dryer
The dryer will not heat. I have no error codes and everything else works fine. I did order a heating element assuming that was the issue but now wonder if I would've had an error code and it could be...
heatman101
Oct 05, 2010 | Samsung DV337 Electric Dryer
I have a Kenmore Elite Gas dryer 2002. Everything works on it except you have to hold the start button down on it. It turns fine, Fires up and heats but let off the start button and it stops. I took it...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Kenmore Dryers
Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer - Blue Logo
329 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
