Question about E-Machines eMachines Desktop PC
Loud Fan Noise
My PC has recently started make loud fan noises.
  • 3 more comments
  • acykay May 09, 2008
    My PC also has fan noises. It sounds like rattling and grinding.
    Is there a solution?
    I usually turn it off to let it cool off. This helps but is only a temporary solution.
    gklauck@hotmail.com
    I will get back with you later. I may be able to do some further research.
    acykay.
  • Anonymous May 31, 2008
    A few times per week a loud fan will turn on inside my PC. No rattling, just a big vacuum cleaner noise. It lasts about a minute then turns off. The PC has never done this in the last 4 years and works fine otherwise, even when the noise happens. It is cool to the touch.
  • alderson506 May 11, 2010
    I Keep getting - LaunchCurlError-28, occurred when trying to connect to BT Yahoo! Mail.
    My Mail Will not load at all.
  • Richard Wilbur May 11, 2010
    What does it sound like? Does the fan sound like it is spinning faster (airplane sound) or is it more like a grinding or rattling?
Hey Guys,
I know it's one year ahead, but I had a similar problem and resolved it. You need a air compressor can to clean out all the dust. My old computer which is 3 years old use to make a very large noise. Simply fixed it by cleaning the processor as it was full of dust
Cheers,
Sky Host Pro
http://www.skyhostpro.com
Posted on Mar 14, 2009
    Scholar:
  • 160 Answers
See that no cables or power wires are touching the surface of the Processor fan or any exhast fans.
Let me know! that your problem is solved and rate me as FIXYA
Posted on Jul 29, 2008
It sounds like it's spinning faster.
Posted on Apr 24, 2008
    Champion:
  • 207 Answers
Usually the fan on graphic card dies first. It can be replaced with another one but I'd suggest you to build in 80 or 100 mm fan to blow directly on your graphic card cooler. Remove the lid and check if perhaps some cable has fallen close/into fan blade. It must be one of those two. I'm 90% certain.
Posted on Apr 23, 2008
    Scholar:
  • 103 Answers
Removing from my que
Posted on May 07, 2008
Excessive fan noise at start up
Check if fans are covered wit dust or wires block the airflow,
if stil u get the sound then you have to replace the fans
Jul 10, 2010 | Packard Bell iMedia 6826 (P481000502) PC...
Air conditioner fan is making a loud noise
1. Could be a caught foreign object between A/C (air conditioning) fan and cooling radiator, producing this loud noise.
2. Could be a damaged fan blade, mowing the cooling radiator.
3. Could be a loud noise comming from the fan's electrical motor.
4. Could be a broken off fin (small wing) of the cooling radiator, striking the A/C fan, producing this loud noise.
Jun 14, 2010 | Dodge Grand Caravan Cars & Trucks
ASUS Lap top computer, 2 months old' makes loud fan type noises at each start up.
Hi
Its normal for a laptop computer or a desktop computer to spin its fans at maximum speed during start up - its part of the power on self test.
If the fan is very loud like on this video the sound is very bad -
that would be a bad fan, constant bad noise. but if your fan only makes noise in start up, its normal.
your warranty should cover the replacement of the fan if its bad.
Oct 02, 2009 | ASUS Z71V Notebook Computer - 15.4"...
Computer noise
More likely one of the fans, but could be the hard drive. Open the case and listen. Fan on power supply, fan on processor, or hard drive are the most likely sources of the noise. Processor fans and power supplies are both cheap and easy to replace. Hard drive is a bit more expensive and you must back it up (which you already regularly do, right?) if you want to keep your data.
Apr 24, 2009 | E-Machines T3112 (RBT3112) PC Desktop
My computer makes a loud noise in the fan
The drive door issue may indicate a virus infection. As to the fan, you would have it replaced. If not under warranty open the case and track which fan the noise is coming from
Mar 25, 2009 | E-Machines eMachines Desktop PC
Hp laptop dv9500 noisy and loud fan ...
The sound you are hearing is probably the fan, This fan has a noisy bearing and will eventually lock up and the fan will stop spinning and therefore the CPU will overheat and shutdown.
The fan needs to be replaced.
Feb 13, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Loud noise
Typical problem in most computers, the fan is experiencing a "burn out." This means there is either something caught in the fan causing it to create noise, or the motor is going bad. there are two fixes for this problem.
1) open you computer's case according to its manual and remove the system cooling fan and give it a thorough cleaning.
2) you may need to replace the cooling fan with its recommended replacement model.
Hope this helps!
Jul 08, 2008 | Gateway 506GR PC Desktop
Cooling fan
Yes. It can be replaced. Try to check which fan is making that sound. Do you have a laptop or a PC? On a PC, there are 3 standard fans inside it. one for the CPU, one for the power supply and one for the computer casing fan as well. It depends on which of those fans it's coming from. On a laptop, some laptops' fans actually makes a loud noise which is common but there is a way that it could be lessened but it might slow down your pc and it might overheat it as well. The loud noise on the fans of a laptop actually indicates that it's trying to cool down the system. If it doesn't stop the loud noise, it could indicate a problem switching the fans back to normal and would just continue to spin fast. Try to contact your PC tech for further diagnostics on the laptops fan to indicate if the problem is with the fan or the mainboard as well.
Jan 02, 2008 | Iomega 33089 250 GB Hard Drive
E-Machines eMachines Desktop PC Logo
948 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
