Question about Refrigerators
I have a Hobart refrigerator Mod. # 03-2 ser.# 32-302-46. The temp started rising slowly, I cleaned the condensor coil and found the evap. coil covered in ice. Is there a defrost for this refrig? And does it run off a time or switch? Any other things it might be, or ideas would be helpfull. Thank you.
If the evaporator coils of the freezer are icing up it is because of auto defrost failure that will stop the circulation of cold air. Check your defrost timer, defrost heater, and defrost thermostat with a multimeter for continuity. If the heater and thermostat are ok then you will need to replace the control board
Posted on Jul 28, 2010
    Genius:
  • 1,478 Answers
Yes, there is a defrost, the defrost timer is usually found behind the front grill "toe kick" of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor. To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode. If it was cooling before, it is now in defrost mode. Simply wait about 35 minutes and check whether it has left defrost mode and has resumed cooling (listen for the compressor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector. The connector can be removed by firmly pulling and rocking it left and right. It is not necessary to note the position of the wires because the connector plug is keyed so that it can be replaced in only one way.
Take care.
Posted on Jul 27, 2010
Compressor not working after performing maintenance ( vacuuming out condensor coil/ fan/compressor compartment )
If you have a start relay , remove and shake - if you hear anything it is toast. with a cap either use a cap tester or just replace it and cross your fingers.
Mar 30, 2017 | GE Refrigerators
Low pressure on suction side and no cooling
If your running 134 a your short of gas
if your running 404a your short of gas
check the super heat it should be 5 ktd
Jan 10, 2014 | True TMC-58-DS Commercial Refrigerator
Temp Rising in Bottom Freezer
You may have a freon leak but check the obvious first. Are your coils clean? Are the condenser and evap fans both running? Is there any ice or frost buildup on the back panel in your freezer?
Nov 09, 2013 | Kenmore Refrigerators
Can you guide me where can I find the right part number for Relay overload starter for my Whirlpool Gold Side-by-side fridge.Mod: GD5YHEXLS01 Ser: SP2325250 MFR DATE:06-03 I am not 100% sure if I rea
Go to sears parts direct web site and put in the model number. Found the page with unit parts our the page that list the compressor. It will have the newest part number
Feb 03, 2013 | Refrigerators
The temp on the freezer side is flashing and the temp is slowly rising.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 24, 2010 | Samsung RM255LASH Side by Side...
The freezer is slowly rising in temperature(0-18 deg in a week, still set at zero) and either side of the unit by the freezer door are very, very hot. Unit is about two years old. Fridge temp is slightly...
Check the condenser fan motor in the back, bottom of unit. pull off lower panel. Fan should be running when unit is running. Also check the condensor coils underneath or in back to make sure they are clear.
Jun 02, 2010 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Refrigeration
Your pressure sound pretty good. I would check the thermostat and the relay on the compressor. If you are getting no frost on your coil, that is usually a tall-tall sign of a bad compressor then it would be better to just replace the unit.
Apr 22, 2009 | Frigidaire FRT21H8 Top Freezer...
GE PSC23NSD SS refrigerator malfunction
Check the cover in back of the freezer for for frost build-up. I think Frost reached the evap fan-blades and stopped it from blowing cold to the ref-side. Contro;s can be confusing. The ON-OFF controls how long the compressor runs, and the other dial how open or choked the airflow from the freezer into the refrigerator. Sometimes it happens that you have that flapper shut and no air is getting moved to the reefer. If frost is on the cover you have dead heater elements on the evap coils or a faulty hi-temp limit switch, which is the disc thingee at the top of the coils. A bad timer also may disallow it going into defrost - think about it. Chris in big bEar
Apr 20, 2009 | GE GSL22JFPBS Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
