SOURCE: Connecting iPod Docking Station to Video 4
On your iPod, go to Videos, Settings, and set it to TV out. Make sure the TV Signal is set to NSTC.
SOURCE: WHERE TO DOWNLOAD FIRMWARE FOR IPOD SHUFFLE
Try setting a partition in hard drive management then formatting it to FAT32, since you might have formatted to NTFS
SOURCE: numark idj2
ok try this do you have a master rest of the idjr? if you do use it and see if this will re initialize the device.
SOURCE: No matter what I do, I can't hook up my Ipod dock to the Denon 397 receiver I just bought.
The receiver is the DRA 397 model. I don't have a solution yet. If anyone does, I'd appreciate it!!
SOURCE: IPOD music list gray in ITUNES
Make sure that MANUALLY MANAGE MUSIC AND VIDEOS is checked.
You'll find it when you click your iPods name.
Check to see whether your iPod shuffle is the original stick version or the newer version, which plugs into the iPod dock connector.
Turn your PC on.
The PC needs to be on to transfer music and charge the iPod shuffle.
Place the iPod shuffle in the iPod dock connector if you have the newer version.
If you're using the original version, then plug it directly into a high-power USB port on your PC.
Check the monitor to ensure iTunes has loaded.
This means a connection was established.
hope this helps
