Question about Dishwashers
MY PLD2850RDC1 Frigidaire dishwasher starts but in about 10 minutes the PF (power failure) lights up but the house has had no power disruption. I can restart the machine but it does it again. What could be the cause.
aborcass
  • 2651 Answers
SOURCE: Frigidaire Dishwasher
PF is merely an indcator to you that you've experienced a "power failure" normal to appear every timr you lose power and/or reset breaker. pressing any one of the buttons will clear it.
Posted on Mar 15, 2008
SOURCE: Frigidaire Dishw. Error code CL
close dishwasher ( cl)
Posted on Mar 18, 2008
SOURCE: My dishwasher runs for bour 10 minutes. Then stops, and flashes PF?
Mine does the same thing. I'm confident that the problem lies in the "computer" which is essentially the buttons for selecting the various wash cycles. That strip is basically a thick band with adhesive on the back by which it is glued to the top of the dishwasher door. There are wires connected to it. The wires run down into the door and connect to a terminal that is built into the door. The inside door panel must be removed to install a new button strip or "computer." Mine was replaced twice in the first year. Now it is three years old and needs to be replaced again. I'm going to look around on the net to see if I can find one.
Davey
Posted on Nov 04, 2008
shastalaker7
  • 1515 Answers
SOURCE: just installed the dishwasher and
Hi, I am doing some Research at this moment. Will get back to you,
Shastalaker7
Posted on Nov 06, 2009
  • 401 Answers
SOURCE: our new frigidaire dishwasher is not running
check the power line to the dishwasher.if all is good call for warrenty service.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Posted on Feb 27, 2010
My Frigidaire Gallery dishwasher has the code "PF" flashing and door latch is not working. Any suggestions.
PF code on Frigidaire dishwasher
Since the PF indicates a power failure, it has most likely lost electrical connection before the control board and this is the most likely place for this to occur. Frigidaire dishwasher (PLD4375RFC0) seems to complete wash cycle but often has power failure (PF) code during the dry cycle.
the latch must be fixed for it to work a broken latch will cause this problem Frigidaire Gallery dishwasher has the code PF Google Search
also we need to know what model it is to recommend a part
Feb 03, 2018 | Frigidaire Dishwashers
I need to know what the error code pf means for a frigidaire gallery model #fgh202465nf1a
Hey Carol, I understand that you are receiving an "PF" error message on your Frigidaire Dishwasher. Typically this error code indicates a power failure. Before considering contacting a service provider, I would recommend resetting the dishwasher by turning off the power to the appliance for about five minutes. After the five minutes return power to the appliance, this should allow the appliance to return to working condition. At this time if you find the problem still persists, you may want to consider contacting a professional technician. The concern could be the control board. Hope this helps! -JK
Oct 11, 2015 | Frigidaire Dishwashers
Frigidaire dishwasher pf dims and stops
Hello Colton Rawlings, thank you for your post!
Based off what you are describing "PF" stands for power failure on a Frigidaire dishwasher. If the lights are dimming then your appliance flashes "PF" it could possibly be an issue within your panel or your appliance is not getting enough power to it. I would recommend contacting a professional to come and diagnose your appliance properly. I hope this is helpful. -Matt
Sep 06, 2014 | Frigidaire Dishwashers
FDB4315LFC2 runs then stops and flashes pf ?
Good Morning Friend,
I understand that your Frigidaire dishwasher, model# FDB4315LFC2, starts and then stops, and flashes a "PF" code when it stops. The "PF" code is stating that there has been a power failure. There could be a possibility that your dishwasher is losing power mid-cycle. I suggest checking your home's circuit breaker, the wiring to your dishwasher, and if you have a cut-off switch, checking that as well. I also suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
My Frigidaire electrolux dishwasher model # FDB2310LCC0 trips a pf code 40minutes into the cycle and it is not the circuit breaker. how do i correct this problem?
Good Morning Doria, thank you for allowing me to assist you!
Typically PF means power failure and you should be able to start a cycle. Unplug the unit or flip the household circuit breaker. Wait about ten minutes and then turn the unit back on. If the error code continues to display, I would suggest contacting a professional to accurately diagnose and repair it.
Best of luck!
Oct 07, 2013 | Electrolux Frigidaire Professional Series...
PF, high temp wash and air dry lights blinking. Reset main breaker but no help.
Hello babe_dog01 - PF typically appears in window when dishwasher is first installed, or when power has been interrupted. HI-TEMP WASH, SANITIZE and START/CANCEL backlighting will also flash. To clear, touch START/CANCEL pad or resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Since you have already done so and it was ineffective contact a professional to move forward accurately. Dishwasher could possibly be experiencing a communication error, wiring failure or faulty control board.
Jan 05, 2013 | Frigidaire FGHD2433KF Builtin Dishwasher
Frigidaire Dishwasher not working at all PF light on panel
PF is a general power failure error code. Reset the unit at the household circuit breaker for about 10-15 minutes, and retry.
Sep 03, 2012 | Frigidaire Dishwashers
My dishwasher starts and runs for 3 minutes then shuts off and flashes PF?
PF IS POWER FAILURE / LOOK AT CONNECTION IN HOOK UP BOX . SOUNDS LIKE THERE GETTING AN CAUSING AN OPEN . WHEN COOL THEY WORK ..MM MAY BE THE CONTROL BUT I DON'T THINK SO ..
Dec 06, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
52 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
