Question about Dryers
When dryen it will stop its self an in the little window E1 is flashing you can go push the start button an it will start up but it will do this many time when tryn to dry a load of clothes it takes for ever to get them dried
  • 171 Answers
Most common cause of this code is an open thermistor.  usually  replacing this cures it.
Posted on Jul 30, 2010
I have a fitness Edge 491 Recumbent bike that the display window reads E1 . the resistance is hard and I am unable to reset. when I press start stop for 2 seconds it all looks like it will reset but then...
The bike is no longer sold and the company went bankrupt in 2014, so neither support nor parts are available from the company. Try the results of this Google search regarding the E1 error code:
fitness quest edge 491 e1 error Google Search
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Nov 25, 2017 | Cycling
Treadmill E1 Error
Version:1.0 StartHTML:0000000168 EndHTML:0000001348 StartFragment:0000000468 EndFragment:0000001331
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
clean the speed sensor, test for open or faulty. tight the connector very well. RUN the software calibration for easy troubleshooting and fix it.
see the diagram attached. and follow steps.
God bless you
Version:1.0 StartHTML:0000000168 EndHTML:0000003648 StartFragment:0000000468 EndFragment:0000003631
The Steps for Newer Style Console Calibration
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Mar 29, 2013 | Exercise & Fitness
Gibson oven door is locked after attempting to do self-cleaning.
Unplug it. Plug it back in, then press n hold start. Make sure lock handle is all the way locked. You may have to push on the door at same time while locking n unlocking. If that doesn't work, shoot it. Ha
Sep 24, 2012 | Ovens
How do i program a black & decker model cm1050w to start coffee breding at a certain time?
I have one. It's easy. Push the program button. The little green light in the lower left corner will flash. The only tricky part is that you only have about 3 seconds to begin setting your time. After that the light stops flashing and you will be changing the regular time. While you are pushing the Hour or Minute buttons you have all the time you need to set your brew time, but once you stop you're back to the 3 second timer. Remember, if the light in the upper left side is on, the time is PM. To turn the timer on, push the Auto button and the little light in the lower left will come on and stay on. To turn it off, just push the Auto button again. Another caution, there is no "safety" for the Hour and Minute buttons. If you push either of those buttons while the lower left light is flashing you are changing the brew start time. If it is not flashing you are changing the real time. In other words, if you push either of those buttons at any time, you are always changing something. Happy brewing.
Sep 12, 2011 | Health & Beauty
I have a Kenmore Range Model 95012102. After canceling the self cleaning oven process the code E1-F5 appeared on the display panel and the oven remains locked.
The F5-E1 error code means that one of the switches on the door latch hasn't fully set itself to the door open(non clean) mode. One thing to try is to open the oven door and push the light switch in by hand while pushing the clean button on the control and see if the latch will open just a little more thusly the switch will open a bit more into the normal mode.
If by pushing the clean button...waiting 5 minutes (whith the door open)then push cancel and see if the latch fully opens..the door latch switch would need to be replaced.
The part number for the latch asm. which includes the switch is W10107820
GENE
Sep 05, 2011 | Kenmore 95012 / 95014 Electric Kitchen...
Why does E1 F5 appear when I'm trying to start the self cleaning steps?
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(*UJHGFD
Mar 31, 2010 | Whirlpool RF368LXKS Electric Kitchen Range
When I push the pressor foot down my machine flashes E1
Is the presser foot lever up or down? It should be down before you step on the foot controller or use the start/stop button.
For additional information, try this URL: http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/HomeSewingMachine/hf_cs6000btieus.html?reg=us&c=us&lang=en&prod=hf_cs6000btieus
Aug 24, 2009 | Brother CS6000i Computerized Sewing...
E1 F5 error on self cleaning oven
Press the self-clean button. The panel becomes blank(---), then press the up arrow( ^ ). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.
This code means the control has detected a problem with the door latch switch. Switch is defective and needs replaced. Part # is W10107820 and cost is $39.99. You can get it at http://www3.sears.com/.
Before calling a repair shop,go to the circuit breaker box and turn off the power to the oven. then turn it back on and then see if the door is released and the error is cleared.
its probaly bent door latch or door sensor gone bad. try pushing on the door when you start the clean cycle see if that helps.
if not our suggestion would be to replace the part....
good luck...
if you got insight into your problem from us , A very helpful rating is appreciated for answering your question
Aug 10, 2009 | Kitchen Ranges
Can not start my oven after self cleaning proceture
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Apr 05, 2009 | KitchenAid KDRS807SSS Dual Fuel (Electric...
Self cleaning does not work
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$$$$
Mar 24, 2008 | KitchenAid KERC700LBS Electric Kitchen...
Dryers Logo
29 people viewed this question
Top Dryers Experts
Marvin
Marvin
