Question about Saeco Royal Professional Espresso Machine
I have a new machine where the Dregdraw Miss is displayed although the drawer is in place. any idea what the problem may be?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
When you pull out the dregdraw you will see a small lug on the side which engaged the micro switch in the machine. Now use a small screwdriver or toothpick and push in the switch to see if itis working.
If it's still working you have to adjust the lug on the dregdraw by heating the plastic and pulling out a bit to engage the switch.
It can happen in the new machine.
Posted on Aug 01, 2010
Gaggia titanium machine, display says dregdrawer missing, even when I've clicked drawer back in place after cleaning it...
Hi
Either your tab is broken on the back of your dredge drawer or your microswitch has been moved from its correct position. There should be a tab on the back of the dredge drawer. If not you need a new dredge drawer.
Sep 13, 2010 | Gaggia Titanium Espresso Machine
Dregdrawer full
Check the back of the drain tray make sure there are no grinds. Then we will have to test the micro switches, remove the drain tray and dregs drawer, insert tray without the drawer, to see if you get an error. A more complicated way is to have the door open place tray minus drawer in machine, then using a small stray or plastic knife, activate the microswitches.
Feb 21, 2010 | Gaggia Titanium Espresso Machine
I have a saeco roayl professional espresso machine
Check behind the drawer, there might be some grinds preventing the it from activing the microswitch.
Jan 25, 2010 | Saeco Royal Professional Espresso Machine
Emtied the dreg drawer when the SAECO machine was off.
Chenk the back of the area for the drawer, there might be some grounds preventing the draw from going all the way in to tell the microswitch that it is in place.
Jan 24, 2010 | Gaggia Syncrony Espresso Machine
Error message: Dregdraw miss
which machine do you have. The drawer is not hitting the micro-switch try puttin a piece or 2 of tape on the tab on the side of the dredge drawer
Nov 20, 2009 | Saeco Coffee Makers & Espresso Machines
I have a Saeco 21103 unit and it keeps getting an error message of ''dregdraw Miss'' what is that?
Hi
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
Oct 27, 2009 | Coffee Makers & Espresso Machines
Dreg drawer cannot be inserted back to its place...
Take the brew unit out, (press the leaver and swing it back together and put it back in the machine,
Apr 10, 2009 | Saeco Royal Professional Espresso Machine
Not working
Three possible causes.
1. The drawer where the coffee grounds end up is not properly inserted. To fix insert drawer completely.
2. The tab on the left side of the drawer is broken off. To fix purchase an new drawer.
3. The drawer microswitch has a problem. There could be many reasons for this. The machine will have to be opened up to see whats wrong.
Dec 02, 2008 | Saeco Royal Digital Plus Coffee...
SEACO Vienna breakdown
If nothing is broken then this might be a easy fix.
first take out the dregdraw and the driptray.
Put one screwdriver on the sensor for the driptray/dregdraw at the botom left and one for the door up i the right corner .
This must be done when the machine is on.
It will then think the brewing unit is in position and move to the starting location.
Jun 21, 2008 | Saeco Vienna De Luxe Espresso Machine
Jura Capress Impressa E8
Open the drawer and take out the box for the grounds. Run a rinse cycle and it should now go back into place.
Sep 06, 2007 | Jura Capresso Impressa E75 Espresso &...
Saeco Royal Professional Espresso Machine Logo
810 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
