Question about HP OfficeJet 7410 All-In-One InkJet Printer
Won't do anything. displays: 00000020. what's up with this thing?
The satellite pro p300 will not start, power, charge lights come on, no beeps. The CD drive initalises. I can put a cide in and the light comes on. There is nothing on the laptop screen or the external...
Check the time if you can, doubt it since it can not display anything.
This usually happen when:
1. The memory card is bad, needs to be replace.
2. The video card is bad. Since it's a laptop, then the problem is with in the motherboard.
Sometimes when the BIOS battery is drained, it also stop the computer from displaying. To see the battery you must take apart the computer.
And the last thing in the list is the monitor it self. Maybe the monitor got damage some how and it won't display anything.
To troubleshoot, I recommend you start with the memory, and since the computer must be 64 bits, it needs 2 memory card of at least 2gb. each stick, if one of them is damage and both are still connected to the motherboard, the monitor won't display anything either.
May 27, 2012 | Toshiba Satellite Pro P300 Notebook
Acer Aspire 5732Z won't turn on - the light comes on for a few seconds and then turns off - whilst the light is on the disk drive will open - the screen doesn't show anything
Could be bad ram,hard drive or possibly a bad display panel or video card.Try using different ram and removing the hard drive then try it.Also,connect it to an external display and see if it shows video or not.If after trying these things it still isn't showing let me know and i'll try to help more.
Nov 22, 2011 | Computers & Internet
HP Officejet 7410 All-in-One Blue screen error message 00000020
I did everything you said, even the angry part lol and still nothing. Sigh...well, I've been wanting an air printer anyway :D
Oct 05, 2009 | HP OfficeJet 7410 All-In-One InkJet...
It said there was a paper jam, but there wasn't
while the error occure unplug the printer to reset the error message.
Dec 28, 2007 | HP PSC 2355 All-In-One InkJet Printer
I could not access BIOS or anything else on my computer.
Starting the PC without memory will result in a ?beep code? error, which is the beeping you are hearing. Replacing the memory should make the beeping go away. As far as accessing your BIOS if you PC won?t display anything they accessing your system BIOS won?t accomplish anything. -When you start your PC with the memory installed do you see anything displayed on the screen? -Was the PC operating correctly before your reinstall? -Why did you void the CMOS? -Why did you remove the PC memory?
Jul 23, 2007 | FIC P4M-915PD1 Motherboard
HP OfficeJet 7410 All-In-One InkJet Printer Logo
320 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
