Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Diminished light I have two Hampton Bay 54 in 5 blade fans with both upper and lower lighting on separate remote control circuits that are about one year old. The lights on one fan unit are considerably dimmer the the other unit. I have rewired the power source with no alteration in the dimmness of the one unit. As usual, the manuals took a hike long ago
  • Anonymous Oct 18, 2008
    I have the same issue. Anyone have the fix?
    Thanks
Solved my problem on a single light model, holding the light button on the remote activates the brighten / dim function. Thanks.
Posted on Jan 04, 2009
When our 2-year-old niece got hold of our Hampton Bay fan remote, we learned from her actions that holding down the button that controls the upper or lower light will, after a pause, either brighten or dim that light. Our fan is older than yours, but perhaps yours works the same way?
Posted on Oct 29, 2008
  • Ryan Jun 05, 2013
    Hilarious. I was looking for a solution because my two-stage dim light would go 'bright' for a second when turning on and then quickly go back to the 'dim' setting. I have a three year old. He likes remotes. And I didn't know if you hold the light button it'll change the setting to dim. Hopefully that is the solution. Thanks.
Change upper light bulbs on hampton bay model 560-084
Please check the manual. If you dont have a manual you can download a free copy from here
Hampton Bay Lighting Manuals
These manuals are courtesy of Hampton Bay
Dec 02, 2016 | Hampton Bay 24002 Ceiling Fan
My remote to turn on the light on my hampton bay fan is not workn
if you replaced the bulbs w/ higher watts it burned the circuit !!
Dec 30, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Fan and remote not working
make sure the main switch is on ,also the chain switch on ,before using control remote!!
Dec 23, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
No switch for ceiling light
Hello joemckeone,
Home Depot sells a Hampton Bay wireless remote for that application. See this link for details
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100072901
Regards,
Rick
Nov 25, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Oct 11, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Hampton Bay Ceiling Fan Windward II
There is a 4 position (dip) switch on both the fan housing and the remote. Make sure these switches are set exactly the same and the remote will control the light and fan separately. If not, the remote may be getting interference on the preset frequency - try CHANGING the dip switches to a different setting and the remote should work.
Jun 11, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton bay fans
inside the remote, and inside the transmitter above the fan there are 4 tiny keys that set the frequency. set each frequency different then the remotes will only operate that fan. However if two lights r on and one off, when u turn the switch off they all go off, and when u turn it back on the same ones should come on. Then label the remotes!!!
Jun 04, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay 54 In. 5-Blade with remote control at wall.
1. Set the remote to run the fan on high.
2. Pull the fan speed chain until the fan reaches high speed.
3. All speeds should work normally now.
The remote is modulating the maximum speed as set by the pull chain.
Dec 29, 2007 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
323 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
