Question about Panasonic SCBT230 Theater System
I can't play any sound from the tv (a Philips ambilight) through the sound system, despite trying every lead configuration in the manual
  • 177 Answers
Make sure that you are connected to 'outputs' on the TV. Make sure that you set the sound system to the correct input that corresponds with your cable. Run a check on the sound system to make sure that the speakers are working and configured correctly using the test-tone facility.
Posted on Jul 27, 2010
Philips 32 Ambilight PF 9986 TV Picture Problems - Fuzzy & Loss of Picture
What are you using for signal to the set? (Box?) and how are you connected? (HDMI?)
If HDMI try going Component
It may be the box/HDMI hook up causing the problem.
Mar 15, 2012 | Televison & Video
Ambilight isn't working when I press ambilight on the remote control. TV is about 5 years old
Have you tried turning it on in the menu options. Navagate thru the menu there is a setting for on or off on the Ambilights.
Jun 08, 2011 | Philips Ambilight 2 52 in. Flat-Panel LCD...
Philips widescreen flat TV model #50PF9966-37 50" plasma, as the tv warms up a loud hissing sounds comes from the back. The hissing sound does not go away when you mute the broadcast sound. when you change...
From what I'm seeing online, the bulbs in the Ambilight may be the culprit. I also read that a firmware upgrade could fix the issue too. There was also a recall of some TV's with that issue, so I would check with Philips about your model and serial number and see if your TV was included in the recall. If you raise enough cain and threaten to never buy from them again, they may get your set fixed for you... even if the warranty is up!
Good luck and please post feedback!
Oct 10, 2010 | Philips Televison & Video
Hi I have a Philips 32inch ambilight TV about
No a lot of HDMI does NOT send the sound signal through the HDMI cable & must be run AV to AV, the RED WHITE & YELLOW plugs Color to color for RED & WHITE, the YELLOW is Composite Video. . The SCART should indeed have it "All in one" however that signal is only RGB, or Composite Video, a lower quality, than HDMI. Just use HDMI & AV. you'll be all good.
Feb 06, 2010 | Televison & Video
50 in philips hd plasma with ambilight model number 50PF9631D/37
The x-sus and y-sus panels have some fuses,check to find out wich panel is broken and replace.
Sep 04, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
I have a philips 42PF9641D/10 and the ambilight on the left side will not come on (lcd tv) any ideas? On turning on the TV both ambilights came on then the left side went off after about a minute!
probably you got a processing unit problem, which makes your tv stopping recognizing the screen information .
you should try resetting all factory default settings, if this doesn't work, you will have to take the TV to an assistance center .
Jul 30, 2009 | Philips 42PF9631D 42 in. Plasma Television
How do you turn the Ambilight on our philips tv?
Hi guys, I have the same model, and after reasing the manual a little closer and skimming the setup menu I've discovered that it's not actually a built in ambient light, it's actually a setting in the picture menu under "active control" that measures the ambient light in the room and adjusts the picture quality accordingly to ensure the best contrast and reduce glare/reflect imaging. Hope this helps....
Jan 02, 2009 | Philips 32PFL7332D 32 in. LCD HDTV
Philips Ambilight
most likely its the audio amplifier board where your having the problems
Jun 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips Ambilight
The correct remote has an ambilight button to toggle ambilight on and off
May 27, 2008 | Philips Televison & Video
Panasonic SCBT230 Theater System Logo
145 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
