Question about Hoover Refrigerators
Freezer getting cold but not freezing food
I have a hoover a Nextra A class fridge freezer
the fridge is work fine but the freezer is not keeping food frozen
the fan is working you can feel the cold but its not freezing cold
    President:
  • 1,099 Answers
..I'm not certain here but there are a couple of things we can look at and diagnose. First, be sure that your doors close tightly. If the gaskets leak, this will allow humidity in...that's where ice comes from. If you 'windowshop', this will also cause icing. Now...let's start with a full defrost. This can take about two days with the unit open and off. Once accomplished, the next thing to do is look at the unit itself. First, underneath, is the condenser coil clean? If not, do that. Now, from the back, remove the felt panel covering the lower portion. The big thing is the compressor. If the unit has been off for more than 20 minutes, clean the big pipe off. Now, start the unit. It should develop frost on the pipe which should either freeze up or dry out after 5 minutes or so. Caution: there is a fan in there! If still frosty, you're low on gas and the unit probably has a small leak. The icemaker can be looked at by removing it. It contains a float. If the float is damaged or jammed, it will not shut off...and will overfill the icemaker. Good luck.
Posted on Jul 28, 2010
I have a Hoover Fridge freezer and my fridge is really warm inside and the freezer is not freezing the food in the top drawer but it is keeping the food a bit cold. What could be wrong with it?
It could be
- a faulty thermostat
- a loss of refrigerant through leakage
- a very poor sealing door gasket
If the fridge is old I'd say you will need to replace it.
Nov 13, 2016 | Hoover Refrigerators
THE FRIDGE PART OF MY FRIDGE FREEZER ,FREEZES ITS CONTENTS.IT IS A HOOVER FRIDGE FREEZER MODEL NO.HNMF2805A-80
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 26, 2011 | Hoover Refrigerators
Freezer stopped working
Pour about 1/2 cup of water into ice maker . If it dumps the cubes , then replace the water valve . If it doesn't , replace the ice maker . Also make sure the refrig coils are clean and free of dust , lint , pet hair , etc....
Aug 12, 2009 | Refrigerators
FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Dec 06, 2008 | Refrigerators
I have a Hoover fridge freezer. The freezer part is working correctly, but the fridge is barely cold, even at the coldest setting.There appears to be only one temperature dial for the whole appliance.
IF THE FREEZER IS FREEZING O. K., THEN THERE IS A RESTRICTION IN THE AIR FLOW. MOST ALL FRESH FOOD COMPARTMENTS GET THEIR COLD FROM THE FREEZER BY A FAN MOTOR IN THE FREEZER. MAKE SURE THE FAN IS RUINNING. IF THERE IS A DAMPER IN THE AIR DUCT FROM THE FREEZER TO THE FRESH FOOD, MAKE SURE THE DAMPER IS OPENED.
Apr 16, 2008 | Refrigerators
Refrigerators Logo
535 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
tom wright
tom wright
JONFRIDGEDOC
Level 1 Expert
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
