Question about Kitchen Ranges
There is no power to my electric range, I checked the fufe box and the plug, I heard a small pop and the light and clock went out. is there an on board fuse that may have blown?
  • Kitchen Ranges Master
  • 6,993 Answers
yes of course, there is a fuse. Trace the fuse firstly from the wall plug. Then trace the wire that comes from the AC outlet into the electric range.
You should find a fuse inside the unit, exactly where the AC outlet enters on the unit.
The fault is obviously a blown fuse.
Good luck.
Posted on Jul 27, 2010
I have a Kenmore electric smooth top range that I cannot use the oven on.
it sounds like the clock assy. cooked or there's a shorted wire somewhere,did the bake element crack or short out?this also can take out the clock assy.if the part is 150 dollars that 's not bad,some of them cost 300 or more.good luck with your oven,also you should have an electrician come in and put the stove on it's own electrical line.
Feb 27, 2013 | Kenmore Kitchen Ranges
Fridgeaire 316246639 model popped oven does not work. Time clock does not work, burners work.
Hello mrstrini2 - Do you have an electric or gas range? Most fault codes consist of both letters and numbers. Could you provide me the code to better address the issue at hand?
Jan 20, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
1999 Crown turned ignition switch to start - heard pop - no electrical power
If nothing works including the lights, something happened between the battery and the fuse box.
There are some fuseable links between the battery and the starter solenoid or between the solenoid and the fuse box.
I'd start with the battery cables and look for those fuseable link wires.
Jul 09, 2012 | 1999 Ford Crown Victoria
Lost our power now on our range we have clock working timer working and burners working. Try to put oven on & the lock button lights up. Try to put broiler on & lock button lights up. Nothing goes...
Ive had the same problem after losing power. I heard to unplug and plug back in the oven and it should work- didnt work for me. Then Ive heard to replace the control board. I found it for $141 on appliancepartspros.com I havent purchased it yet, still searching to see if this is really the problem
Feb 20, 2011 | Maytag PER5710 Performa Electric Kitchen...
Electric range heard a loud bang then it went dead
I WOULD DISCONECT THE POWER AND REMOVE THE BACK PANNELS AND LOOK FOR A SHORTED WIRE OR A BURN MARK ON THE BOARD. ALSO CHECK WHERE THE CORD ATACHES TO THE STOVE. GOOD LUCK!
ERIC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 17, 2010 | Kitchen Ranges
Fixed power cord, clock works, doesn't heat
SkyKing, are you handy with a meter? sounds like you are losing a leg of power here. Check for voltage at the terminal block (where the cord hooks up. You should read, 120V from left to center, 120V from right to center and 240V across the two outer terminals. Check this first and post back. Catriver.
Apr 18, 2007 | Jenn-Air SCE30600 Slide-In Electric...
No display - oven/timer/clock inop.
Most likely control / clock has gone bad and needs replacing
Nov 11, 2017 | Frigidaire GLEF396 Electric Kitchen Range
Kitchen Ranges Logo
20 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
