Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
I want to erase my sandisk flash drive that I have business papers on and re use it. How do I do it?
  • 472 Answers
click on start and go to my computer >> right click on your flash drive icon and click on format >> confirm the format and you are done. You can re-use it then.
Good Luck!
Posted on Jul 27, 2010
Deleted new files from my flash drive
If you erase the files, (SanDisk backup and security system files) it will still work but you can not use the backup system on the drive.
Dec 14, 2017 | SanDisk Cruzer Glide - USB flash drive -...
Help How can I unblock my sandisk cruzer
Dear Customer, Plz Flow this instruction i think solve you problem.
Reformat the drive:-
  • Right-click the SanDisk flash drive within "Computer" and select "Format..." Enter a name for the drive, select your desired format (FAT32 is typical for flash drives). Click "Start" to format the drive. This, unfortunately, will erase everything on the drive. Any data contained will be lost along with the password protection. Once reformatted, the drive will be fully accessible.
Sep 12, 2012 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My 8GB SanDisk Cruzer when plugged in lights up, but it's not detected, both on Windows and on Mac, I don't know if it's still fixable... :(
Try reformatting your thumb drive. Here's how to do it on a Mac:
**THIS WILL DELETE ALL THE DATA ON THE DRIVE**
1. Open Finder
2. Applications 3. On the left column, you should see your thumb drive. Click on it.
4. Click on the "Erase" tab near the top
5. For "Format:" select "FAT32"
6. Click on the "Erase..." button
Feb 01, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I need help resetting my flash drive memory. I am a Mac user, so the below tips don't seem to apply to me. Thanks.
1.Place the flash drive on the desktop.
2.Start the "Disk Utility." Click on "Macally" flash drive. Use the "Erase" button.
3.Select the "MS-DOS File System" in "Volume Format."
4.Provide a new name for the drive.
5.Click the "Erase" button.
6.Perform the instructions given on the screen and finish the formatting.
Oct 25, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Dear Team Today when i try to use my CRUZER U3 (8GB) I GET MESSAGE "you have reached the maximum number of failed password...
Each U3 smart drive comes with a pre-defined number of login attempts. When you have only 3 attempts remaining, you will receive a warning message to prevent losing your data unnecessarily.
SanDisk does not have any method to bypass the password security feature on Cruzer U3 flash drives. SanDisk has not built in any back door or password reset methods. If the password feature is enabled and you exceed the number of incorrect password attempts, the drive will lock. Once the drive is locked there is no way to unlock the drive or gain access to the data stored on the device. You can only select the format feature, which will perform a secure erase (drive wipe) and data recovery will NOT be possible. U3 Cruzer flash drives which are password protected use 128bit AES encryption for data security
http://kb.sandisk.com/app/answers/detail/a_id/191
Sep 23, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Eraseing a sandisk 2 gb flash drive
To Erase everything on the drive you can format it. To do this, plug it in, then go to 'my computer' Right click on the drive, and select 'format'. BE AWARE, THIS WILL COMPLETELY ERASE EVERYTHING ON THE DISK! So make sure that there is nothing that you want to keep on there.
Jul 27, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
When I put my Sandisk 2gb Micro SD card into my Mac, it says the capacity is full, but there is no items in the card, how do I fix this?
Press command(apple)+space and type disk utility
Select your SanDisk on the left and erase. Choose FAT
You can also rename it
Jul 19, 2010 | SanDisk 4GB microSD High Capacity Memory...
4gb SanDisk Cruzer Titanium not working
"limitation is that flash memory has a finite number of erase-write cycles. Most commercially available flash products are guaranteed to withstand around 100,000 write-erase-cycles, before the wear begins to deteriorate the integrity of the storage"
This means that your flash card may have been damaged by not removing correctly Flash card are not that reliable AS previous pen drives
just a sugestion
Dec 22, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
Erase Data?
If you goto My computer and click on the Appropriate Letter for your flash Drive you can then Right click on it and go to "FORMAT" and then from there click Ok or Next. This will erase all data on the flash drive. You can also physically open the drive in my computer and select everything by pressing CTRL and A at the same time and then pressing the DELETE key on your keyboard, either one works fine and will delete the data off of a flash drive. Hope my answer gets you closer to a solution. Please Help rate me if I helped you out or not I am new but a very good tech.
Aug 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
22 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
