Question about Toshiba Televison & Video
The sound on my toshiba 26wl36p has stopped working through the speakers I think my son has pressed a button
3 Suggested Answers
electrotech1
  • 1126 Answers
SOURCE: My son played with the remote and accidentally
You have to go into the menu and go to sound set up and turn the internal speakers on. If that don't fix the audio problem, it is possible the audio processor is locked up. To fix that problem you need to unplug the TV from the wall for 40 MIN, and that will reset the processor back to normal.
Posted on Dec 06, 2010
electrotech1
  • 1126 Answers
SOURCE: my son played with the
Go into the menu and go to sound or Audio set up,and then to internal speakers, and turn them on. If that don't take care of the problem then the audio processor could be lock up.. Then you need to unplug the The TV from the wall for 40MIN. and that will reset it back to normal.
How do i fix Sound has stopped working in my Toshiba Laptop
This my sound simple, but is it muted through the speaker icon (a red line through it) or by inadvertently hitting a button on he laptop itself? The wifi on many laptops can also be turned off by hitting button on the keyboard, the wifi light or led itself.
a model number can be helpful. I also have ability to remote in to fix it if I is online.
Nov 29, 2015 | Toshiba Toshiaba Tecra High Performance...
How do I enable the buttons to the right of the power button? These touch buttons are between the speakers, to the right of the power button, and are used to decrease and increase volume, mute sound, play...
If the buttons are blue, try holding down the FN key when pressing them. If they are buttons that are not on the keyboard, there is a driver to enable them that you should be able to find on the support site. Official Toshiba Support Toshiba Put in your model number or serial number and check out the drivers tab.
May 28, 2014 | Toshiba Satellite PSAY1U-00V005 P755-S5265...
All speakers stopped working just after my son pressed some buttons on our absence. what could be the problem and how to overcome it?
If he pressed buttons on your receiver/amp, there are a few things that will cut out the sound:
* Changing inputs
* Pushing mute
* Toggling the speaker set (shown as Speaker A and Speaker B)
Jan 12, 2014 | Audio Players & Recorders
My son installed speakers on my Toshiba laptop
Right click on on the speaker icon. Click on adjust audio properties. Under the volume tab, if the mute is selected, deselect it. click advanced under the speaker settings. Select laptop stereo speakers.Click OK. close all windows. Restart.
Jan 25, 2010 | Toshiba Satellite A135-S4527 Notebook
No sound
More than likely you need to go into your menu settings. Check to ensure that your TV speakers are enabled. The previous owners may had it hooked to theater system
Oct 20, 2009 | Toshiba TP50G60 50" Rear Projection...
The son froom my speackers stop
my best guess on this one is probably not the speakers but the sound system or device sending the signal to the speakers or the wiring to the speakers is shot if you are sure that all of this is fine then the problem is the speakers do not have enough power to play and it might be the psu that is shot.
Aug 22, 2009 | Yamaha HTR-6030 Receiver
I have a 32AF43 remote has stopped working
resolder the ir sender it sound like it the solder has broken free
Jun 23, 2009 | Toshiba 36AF42 36" TV
Acua MDX 2004 Speakers, left side dont work
try pressing the right button of your stereo 3x which i think is for the balance of the speakers probably it is only balanced on the left side just put it in the middle
Mar 14, 2009 | 2004 Acura MDX
Can not get 3 speakers on my samsung home theater to work!
There are a few settings that will just give you a stereo output. The first one is with the Pro Logic II. If you press the PLII Mode button on the remote it will go through a series of settings from MUSIC ➞ CINEMA ➞ PRO LOGIC ➞ MATRIX ➞STEREO ➞ MUSIC. Pro Logic setting will only produce sound from the front speakers and Stereo from the front speakers and the sub. Put it on Matrix for 5.1 surround sound.
Also for speaker settings follow the instructions below.
Signal outputs and frequency responses from the speakers will automatically be adjusted according to your speaker configuration and whether certain speakers are used or not.
In Stop mode, press the MENU button.
Press the Cursor down button to move to Audio and then press the ENTER button.
In the SPEAKER SETUP, press the ENTER button again.
Press the Cursor button to move to the desired speaker and then press the ENTER button.
For C, SL, and SR, each time the button is pressed, the mode switches alternately as follows : SMALL ➞ NONE.
For L and R, the mode is set to SMALL.
SMALL : Select this when using the speakers.
NONE : Select this when no speaker is connected.
Press the RETURN button to return to the previous level.
Press the EXIT button to exit the setup screen.
It also seems that with this system, if you are on 5.1 surround but your music source is only in stereo, you will only hear stereo.
Nov 20, 2008 | Samsung HT-Z310T Theater System
Televison & Video Logo
42 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
