Question about Kohler Home
Un level Kohler toilet.
How do you level the tank of a commode (Kohler, k-11821) if you dont want to shime it which can lead to cracking? the floor bowl is level.
    Novelist:
  • 145 Answers
If the bowl is level the tank should be level. It doesn't really matter if it is a little off level, unless your having flush problem, and no you definitely don't want to shim it. The problem may be that one tank bolt is tighter than the other. Note: Be careful when messing with the bolts. If on is too lose you can tighten it, but if you try to loosen one you risk breaking the seal between the tank and the bowl.
Posted on Jul 28, 2010
Why is tank wobbly upon install on kohler archer toilet?
The tank mounting bolts could be loose or the tank could be incorrectly seated. Be careful not to tighten the bolts too much and crack the tank.
Jul 20, 2014 | KOHLER Archer Toilet Tank, White
Kohler one piece toilet. it is leaking around the bottom of the toilet but if I put the water in the back of the tank myself, it doesn't leak
if its leaking from bottom of toilet on the floor. its the wax ring that may be bad, if it does this when flushing it is either cracked or the wax ring under toilet is bad.
Mar 26, 2012 | Kohler Home
When I put the tank on and tightened the 3 bolts I had a leak on the right bolt but the tank was level.So I tightened it up and stopped the leak but it isn't level anymore
This happens when the floor is not level. You need to keep the tank tight to the bowl. Silicone a shim under the lid on the low side to make the lid level. This will make the tank look level also
Aug 23, 2011 | Kohler Cimarron 2-PC Elongated Toilet with...
I have a slow drip that is coming from the bottom right edge of the tank area. It looks as if it's actually coming from the "skin" of the porceline. I layed down under the toilet and...
Hi patty oliver...
I agree with your husband, it sounds like a hair line crack in the tank.
One thing to check:
Check to make sure the tank in level while it is attached to the base of the commode.
If it is not, then it can cause a leak at the edge of the tank by the water by-passing the seal of the tank to the commode and running to the edge of the tank giving it the appearance of the tank is leaking.
Wipe up all the water you can and see for sure if the water is coming from the edge of the tank, if so then you may need to replace your tank.
Or you could dry your tank very good and try to seal the hairline crack with silicone sealant and let it set overnight then reinstall to see if the leak has stopped.
Free Answer...Please take time to rate me
Jun 07, 2011 | Eljer TITAN One-Piece 1.6 GPF Toilet -...
I have a new Kohler Toilet that has a different flushing system from other Toilets. It's about 1 year old now and I'm noticing a Drip noise on the 1st floor under this Toilet. It looks to me like the water...
Basically, if water is flowing out of the overflow tube, then water must be coming in...I would suggest that you check the intake valve, it is probably not shutting off completely when the float comes up to the prescribed level,and continues to leak some water into the tank. That is what the overflow tube is there for.
Mar 17, 2011 | Kohler Toilet - One Piece with Ingenium...
Recently installed Toto toilet by a qualified plummer(twice) it still rocks side to side and back and forth. Floor is level. Toto Toilet Aquia11
Qualified? Plumber? sounds like it needs to be shimed,because not all floors are exactly level,or castings of toilets exactly perfect.Doesn't sound like the handyman knows what he's doing.Shims available at home depot--plastic-don't shim with wood-it will rot.I've used various coins to get right thickness.Be careful tightening bolts,you'll crack bowl.Find a legit plumber licensed
Feb 15, 2011 | Home
Toilet is unstable with respect to the floor. it rocks when you get on and off it.
It needs to be shimed,either floor uneven or casting is not uniform.It is a problum most people don't understand.Toilets when set need to be leveled if not you can break bowl.Go to home depot and in plumbing dept. ask for plastic shims-come in little bag,tap under toilet and then snug down bolts,(don't reef on bolts)when shes tight take flat head screwdriver and hammer and chop off shim flush.You should take dap tub and tile caulk (water soulible) and dap around bottom-keep wiping sponge with clean water around till it looks nice let set up for 12-24 hours,toilet should be rock solid.If by chance its leaking around base you'll have to reset with new wax Richie
Jan 27, 2011 | Kohler - Toilet - Two-piece - Highline -...
My kohler toilet is only about 1 year old. no problems with the flush but the bowl only fills up with about half the amount of the normal water. I looked inside an all seems to be connected. Thanks
You might follow this link to see if you can adjust the water level:
http://www.acmehowto.com/howto/homemaintenance/plumbing/toilet/filllevel.php
Hope that helps.
Aug 21, 2010 | Kohler Home
What can I do to assure that my commode won't overflow? I came home after being away a week, and my basement was flooded due to the upstairs toilet leaking. Plumbers say it was just clogged. It totally...
Turn off the water at the valve going to the tank of the toilet. The valve is normally located half way between the tank and the floor, on a pipe leading to the tank. The water in the bowl will last over a week and should not be a problem. Good luck, I hope this helps Please rate me, Thanks
Dec 30, 2009 | Crane Plumbing Toilet To Go Tall...
Need to know which cadet to install--3 or 4
I only install Kohler commodes and have never had a problem with clogging. All of Kohler commodes have a 3.5 inch flush valve, just pick the style you want.
Jul 08, 2009 | American Standard Cadet 3 Right Height...
Home Logo
331 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
