Question about Code-Alarm Code Alarm Transponder
I have a 1996 Ford Ranger. Apparently a security system was added to the vehicle after it was first purchased in Broomfield Co. I bought it used in the late 1990's. Something kept running the battery down. I took it to a mechanic and he checked everything fuses power etc. And believed the problem was the security system. He disconnected the security system and now I do not have any problem with the battery. However I do not have wipers windshield washer dome lights. He check the power in each of the items and there was power but they do not work. What is the problem? Please let me know. Thanks
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Disconnect the alarm. No one is going to steal a 96 ranger. Trace the wiring as the alarm intercepted the ignition, which you will have to reconnect. Pay attention to color codes and wire sizes if you do not have a diagram. Water proof the new connections.
Posted on May 30, 2017
SOURCE: Which fuse controls windshield wipers on 1996 Ford Contour
I just pulled out every fuse one by one to see if they were broken and I found one that was broken and replaced it and now my windshield wipers work.
Posted on Jan 10, 2009
bigTROY502
  • 129 Answers
SOURCE: I replaced the starter. Disconected the battery
Place your key inthe ignition, and turn it to the on position. Leave it forward for 1 hour, and then try again. This is how you reset the FACTORY alarm.
Posted on Aug 10, 2009
Douglessd
  • 284 Answers
SOURCE: 2001 Ford Ranger Extra Cab windshield wipers don't
WOW that is strange. Get your self a test light or a cheap multimeter. Take the + wire off at the wiper motor and check if you have voltage / power. If you do then the problem is with the wiper motor if you don't it is the wiring or the switch. I know, not a complete solution but it cuts your problem in half :)
Good Luck
Posted on Aug 15, 2009
SOURCE: Aftermarket anti theft system problem
Found the problem - it was not the security system - it was an internally shorted battery. Replaced the battery and the car is fine.
Posted on Oct 13, 2009
  • 30 Answers
SOURCE: 2000 Ford Ranger XLT Automatic trans. 4X4 3.0L
Check your operator's manual. Make sure any and all fuses that have anything to do with the affected items are not blown and are working properly. If you can; check for loose fuse connections or wires. Hope this helps. God bless!
Posted on Dec 09, 2009
Where does a evap sensor go in a 1996 ranger pickup
I'm not an expert and I have a similar problem on the 1996 Mazda extended PU w/2300 four cylinder. Same vehicle, made in ranger plant in NJ.
On the four, the purge solenoid and the purge flow sensor are located just aft (towards driver) of the battery on a vac line between the canister (next to the battery) and the intake (Just forward of the brake master cylinder.
QUESTION: Is there a pressure sensor in the fuel tank of this vehicle??????
Sep 22, 2012 | 1996 Ford Ranger SuperCab
Is there a OBD11 connecter on a 1994 f-250?
OB11 is compatable with 1996 & later vehicles only. You may purchase a code reader that is compatable at any parts store or Ford dealer for your vehicle. Hope this helps. Happy motoring!
Oct 12, 2010 | 1994 Ford Ranger Supercab
Need manual for 1996 stx ranger 4wheel drive truck, wgere can I purchase one?
You can purchase one at a automotive store or order one online
Jul 18, 2010 | 1996 Ford Ranger SuperCab
NEED TO REPLACE FUEL PUMP FOR 1996 fORD eXPLORER, V6 4.0. WHERE IS IT AND HOW DO I GET TO IT?
Great SUV, I have the same model; for Ford Ranger/Explorer/Mountaineer 1991-1999 check this procedure to Fuel Pump - REMOVAL & INSTALLATION...
(see Figures 1, 2 and 3)
To gain access to the fuel pump, it is necessary to remove the fuel tank.
  1. Depressurize the fuel system and remove the fuel tank from the vehicle.
  2. Remove any dirt that has accumulated around the fuel pump attaching flange, to prevent it from entering the tank during service.
  3. Turn the fuel pump locking ring counterclockwise using a locking ring removal tool and remove the locking ring.
  4. Remove the fuel pump and bracket assembly.
  5. Remove the seal gasket and discard it.
To install:
  1. Put a light coating of heavy grease on a new seal ring to hold it in place during assembly. Install it in fuel tank ring groove.
Fig. 1: Fuel pump and sending unit used on the Regular Cab Ranger pick-up
Fig. 2: Fuel pump and sending unit used on the Super Cab Ranger pick-up
Fig. 3: Fuel pump and sending unit used on the Explorer and Mountaineer
  1. Insert the fuel pump assembly into the fuel tank, then secure it in place with the locking ring. Tighten the ring until secure.
  2. Install the tank in the vehicle.
  3. Install a minimum of 10 gallons of fuel and check for leaks.
  4. Install a pressure gauge on the throttle body valve and turn the ignition ON for 3 seconds. Turn the key OFF , then repeat the key cycle five to ten times until the pressure gauge shows at least 30 psi. Reinspect for leaks at the fittings.
  5. Remove the pressure gauge. Start the engine and check for fuel leaks.
Hope help with this; remember comment and rated this help. TY for using Fixya.
May 28, 2010 | 1996 Ford Explorer
How can I disarm the anti-theft alarm on my 2004 Ford Fiesta
If you are talking about the factory alarm, that is disabled simply by turning the ignition key to the run position.
If this instead is a third party alarm , then it will have a valet override button sowmehere under the dash.
Nov 25, 2009 | Accessories Alarm Siren
Diagram of 1996 ford ranger fusebox which fuse is
RANGER FUSE PANEL Fuse Position Rating Circuit Protected 1 7.5 Amp Power Mirror 2 — Not Used 3 15 Amp Parking Lamps 4 10 Amp Left Headlamp 5 10 Amp On Board Diagnostic (OBD) II System 6 7.5 Amp Air Bag System/Blower Relay 7 7.5 Amp Illumination Switches 8 10 Amp Right Headlamp/Fog Lamp System 9 10 Amp ABS System 10 7.5 Amp Speed Control/GEM System/Brake Interlock 11 7.5 Amp Warning Lamps 12 10 Amp Front Washer System 13 15 Amp PCM System/Stoplamps/
4WD/ABS/Speed Control 14 10/20 Amp ABS System 15 7.5 Amp Air Bag System/Alternator 16 30 Amp Front Wiper 17 15 Amp Cigar Lighter 18 15 Amp A/C System 19 25 Amp Ignition Coil/PCM System 20 7.5 Amp Radio/GEM System/Anti-Theft 21 15 Amp Hazard Lamps 22 10 Amp Turn Signals 23 — Not Used 24 10 Amp Starter Relay/Anti-Theft 25 7.5 Amp Speedometer/GEM System 26 10 Amp 4R44E/4R55E Trans./Backup Lamps/DRL System 27 10 Amp Underhood LP/Map Lights/Glove Box Lamp/Dome Lamp/Visor Lamps/4x4 Sys. 28 7.5 Amp GEM System 29 10 Amp Audio System 30 — Not Used 31 — Not Used 32 — Not Used 33 15 Amp High Beam Lamps 34 — Not Used 6d47eae.gif
Nov 01, 2009 | 1996 Ford Ranger SuperCab
Where are the timing marks at on a 1996 ford
I recommend you get the Haynes repair manual for your vehicle. This replacement will require removing many parts from the motor and aligning components that are normally not visible. If you fail to align the timing marks properly before installing the new built you could cause serious damage to your vehicle.
Oct 17, 2009 | 1996 Ford Ranger SuperCab
O reading for O2 sensors on 98 Ranger XLT
Yes the 98 ranger has 3 02 sensors,they are located in the exhaust system under vehicle,2 of them
are in front of the cataletic converter and 1 behind it.I replaced mine ,reset the codes and the check
engine light still comes on?
Jan 16, 2009 | 2004 Ford Ranger
Code-Alarm Code Alarm  Transponder Logo
171 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
