Question about Sony Playstation 3 (PS3) Console
Yellow light then solid red - Sony Playstation 3 (PS3) Console
    President:
  • 1,139 Answers
This is called the Yellow Light of Death. This indicates a general hardware failure normally due to overheating. When these PS3's were produced Sony decided to use lead free solder. The problem with lead free solder is that it is not as flexible as leaded solder but it is cheaper and more environmentally friendly. When the console gets hot and cools down hairline cracks appear within these solder joints and a good electrical contact cannot be made. This then causes the console to fail. It could be on a number of different components including the CPU, GPU or memory. There is a temporary cure that may or may not work but ultimately the console will need to be repaired professionally or replaced. If it is out of warranty Sony will not replace it but will offer a refurbished unit for around £130. If you look on Youtube for Yellow light of death fix there is a way that you can re-heat the solder joints using a heat gun but if you are not confident taking apart electrical items then this really may not be something you want to try.
I am sorry I cant give you any better news but unfortunately it is a very common problem with the PS3.
Hope this helps and thank you for using FixYa
Posted on Sep 25, 2010
Red light - Internet
Not internet connection. You will need you IP to come check the lines.
Nov 14, 2017 | Zyxel Computers & Internet
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
I have replaced the coil pack on my 2002 ford taurus with the 3.0 24 valve engine. I have no spark to cyliders 3 and 4. I have also replaced the electical connector to the coil pack as well. All 4 wires...
All 4 wires have power and the yellow and white and the yellow and black pulse with the test light, the yellow and red and the solid red wire have a steady light with no pulse. The PCM - engine computer is no good , driver (transistor's) in side turn the coil on an off . Burnt transistors .
Mar 30, 2017 | 2002 Ford Taurus
The power light is solid red with no light on the status. I took out the bulb and put it back in now I have a solid red on the power and a solid yellow on the status. There is also no sounds coming from...
steady red with yellow/orange status light indicates that the temperature is too high, so by the sounds of it your device has malfunctioned, you need to get a repair on this
see page 44 here
http://vis.mitsubishielectric.co.uk/files/library/files/hc3800_manual.pdf
different model but same error code
Mar 06, 2011 | Mitsubishi HC3000U Multimedia Projector
I need to know the pin outs on the wiring harness for brake light,running light and turn signals.
Orange/white = Switched 12 VDC (tail light)
Red/yellow = Stop light
Solid brown = Right turn signal power/signal
Solid purple = Left turn signnal power/signal
Solid black = Ground
Aug 08, 2010 | 2004 Harley Davidson FLSTC - FLSTCI...
Brother Printer HL 5250DN
A solid red STATUS light with a solid yellow TONER light indicates toner out...replace according to pg. 63 in the manual.
It can also indicate a cartridge position error. Take the DRUM UNIT out of the machine and re-install.
A solid red STATUS light only means:
Front cover open
Fuser cover open
Dust on drum
Too many trays
Buffer error
Print overrun
Memory full
Download full
Font full
See pg.48 ofthe manual.
Oct 02, 2009 | Sport & Outdoor - Others
Aftermarket radio does not work
The wires in the radio are more likely:
RED : Main Battery Power
YELLOW : From Ignition Switch
BLACK; Ground
BLUE: Output for Accesory (Antenna o Amp)
Car;
Blue/Red: Main Battery Power
Pink/Black : From Ignition Switch
Yellow/Gray: Illumitation(Don't use)
Green/Black: Same
I may be able to email you a copy of the diagram (just to be safe...)
Sep 13, 2009 | Car Audio & Video
Beep 3 times turns green yellow then blinks red then turns to a solid red wont turn on wont give me game
3 Solid Red lights usually means that a cable is unplugged. Check all cables (unplug and plug back in)...you may need to replace power cable if issue is still ocurring. If it is 3 Flashing red lights, this is known as the Red Rings of Death, i.e. your XBOX is dead and needs to be completely replaced.
http://www.xbox360forum.com/forum/xbox-360-console/64180-what-do-three-solid-red-lights-mean.html
Jun 16, 2008 | Video Game Consoles & Games
Broadband 2nd Light keeps blinking yellow and then a solid red Light
Ask your Paents to ring the company they connect with it seems to be emulating a disconnection for some reason?
Sep 05, 2007 | 2wire (1000-000057-000) Modem
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
