Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Brother mfc240c not detecting black ink cartridge. When I remove the cartridge and replace it with another it will not detect that the cartridge has been removed.
  • 268 Answers
on the ink cartridge, midway between the two holes that plug into the printer, there's an opening. evidently, the printer senses ink level thru the little piece of plastic.
with printer OFF, take all ink cartridges out. cut small pieces of duct tape, small enough to cover the hole but not pass the catridge edge. use a small screwdriver or tip of a knife blade to work the edges of the tape into the slot, covering the little plastic window.
insert back into printer. worked for me. it's simpler than it sounds.
Posted on Jul 28, 2010
  • bharat patel Jul 28, 2010
    Goodbye MFC time. all the best.
  • SUPERBIGMAN Aug 18, 2010
    I have a mfc-240c and was having trouble with the machine not even detecting black cartridge. As a tip from another site I lifted the scanner glass portion up, and removed the 3 screws at the top of controls. I then clipped the 5th wire on the 9 pin white wires plug that is attached to the circuit board. This disables the sensors and the machine works fine now. You just have to replace ink when it starts to fade
Cutting the 5th wire worked wonders thanks friend
Posted on Oct 20, 2011
My MFC-430W wont recognize color ink cartridges
Faulty Sensors or Cartridges if they are compatible
Sep 14, 2014 | Brother MFC Office Equipment & Supplies
Re: brother mfc 210c printer-fax. will not print black- only color. have replaced black cartridge w/ no improvement
Try removing the colored cartridge and see if it will print. Also on your print settings try to see if you can select print using black only. next look at the black cartridge and see if ink is flowing or if there are any blots or clots that would stop the ink.
Sep 16, 2008 | Office Equipment & Supplies
I have replaced black ink on a hp deskjet 960c and the red light keeps flashing
I see you replaced the Black in on your HP printer but the light keeps on blinking still.
Make sure that you remove the silicon film from the ink cartridge before installing in the printer, if that file is not removed the contact to the printers ink will not detect the ink cartridge at all.
Also try to remove all the ink cartridges and install all of them at the same time , this is to reset the printer from detecting all the printer ink cartridges.
I hope this helps
Oct 26, 2011 | HP DeskJet 960c InkJet Printer
My brother dcp-165c cannot detect the black ink catridge please help me to solve my problem
Remove the cartridge and reinsert after switch off. Now un-install the driver from the PC and reinstall , then connect the printer which will be detected and new hardware installed.
if the cartridge is not found then there are faults in the main board.
Feb 05, 2011 | Brother DCP 165C Compact Color Inkjet...
Brother mfc240c will not print
Are they genuine Brother ink cartridges? Some Brother models won't accept generic or non-OEM ink. Try replacing them with genuine Brother cartridges.
Oct 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
Not detecting ink cartridge - or saying empty - Brother MFC 240c
Is it an ORIGINAL BROTHER cartridge ? ?
OR
A cheaper version ? ?
Aug 22, 2009 | Brother Multi-Function Center MFC-240C...
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
Brother MFC-420cn NO CARTRIDGE message. I replaces black ink cartridge . How to detect which cartridge needs replacement when all of them seem to have ink in them.
Here's a permanent fix. Basically you cut the wire to the ink sensor. You can no longer see the ink levels, but that didn't matter anyway, as it was incorrect before!
First of all, TURN OFF THE POWER TO YOUR PRINTER. Then lift up the scanner and remove the three screws along the top of the control panel. With a bit of force, snap-up the most inner two
Sep 05, 2008 | Brother Office Equipment & Supplies
Does not accept black ink cartridges
Did you use generic ink? These generic carts are different (no seal to prevent staining). This carts stain the led control circuit board which has to be replaced by a new one (the spare part is only avaiable as the whole ink cart holder incl. led board and tubes).
There is no way to do a short fix, sorry!
Nov 28, 2007 | Brother MFC 240C All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
414 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
