We have a Goldstar portable AC. It runs fine but
We have a Goldstar GP120CE portable AC. It runs fine but doesn't cool. The compressor sounds like it cuts in but does not seem to cool the air? The exhaust duct is not hot as it once was. It has had light use, is clean, and only 2 years old. Ideas?
  • 43,501 Answers
Refrigerant leak.....not worth fixing.. will cost more then a new one...
Here is a tip for other things you can check first....
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 27, 2010
I have a Goldstar A/C model #GP120CE that quit cooling. I think the compressor is not working. Is it worth fixing?.
Check Thermostat setting, if its ok then make sure for compressor working or not.
Or try to change thermostat only if u r unable to get the result.
Compressor having long life its rarely being NG.
Hope your answer is completed.
May 17, 2018 | Goldstar Refrigerators
My Dometic roof top ac doesn't cool. Fan runs fine, no COOL air. With thermostat in off position. Checking the voltages I found 118v at the breaker. At the run relay, 118v going in and a coupl
Please reply with Model number of bottom of AC unit ( upper) . Can be seen from inside usually. Thermostat model, plus if controls are at the ceiling assy or at thermostat on wall.
Jan 17, 2013 | Dometic Rooftop RV Air Conditioner
Our Danby model dpac 11006 was working fine yesterday but came to put it on today just to find out the ac doesn't work the fan still blows just no cool air . we do hear something in and out like a...
The intermittent sound you're hearing is probably the compressor trying to start. This could be caused by a bad circuit or the compressor motor is seized If the latter is the case, it's time to start shopping for a new AC. As the cost to repair would be almost as much as a new unit depending on the age of your unit. However, compressors usually have a 5 year limited warranty. So check you Owners Manual for details. It may still be in warranty.
Hope this helped you and thanks for choosing FixYa.
Aug 11, 2011 | Danby Portable Air Conditioner
Goldstar GP120CE portable air conditioner with the E3 error
Sounds like a clogged condenser pipe which is common for portable Ac . It is usually due to the unit sitting low and collect more pollens an particles at floor level. A pipe cleaner tends to do the trick. Also insects tend to harvest inside the drain pipe
Jul 15, 2011 | Heating & Cooling
I've had my air conditioner for a few years now and it no longer cools anything. The fan works, the condenser(?) turns on when I set it to cool instead of fan, but the air coming out of it isn't...
You need to determine if the compressor is running, if it is and you have no cooling then you either have lost charge or bad compressor, these units re not worth replacement compressor
Jun 22, 2011 | Goldstar R5208 Air Conditioner
I have a Goldstar GP120CE Portable with an error code E3. What do I do to fix it.
If you have a goldstar GP120CE portable air conditioner with the E3 error and it's not under warranty you may be out of luck.When I called LG, (who owns Goldstar), they said these units are not cost effective to repair so finding a company to service them is difficult. If it were under warranty they would exchange it..
Jul 09, 2009 | Goldstar Heating & Cooling
Air conditioner not cooling
You can't tell if you have a refrigerant leak unless you put gauges on. You may not have any sign of a leak and still be out.
Mar 31, 2009 | Goldstar Heating & Cooling
Running Compressor Intermittently
replace the thermastat it has a bad set of contacts
May 05, 2008 | Goldstar R8000 Air Conditioner
Heating & Cooling Logo
546 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
