Aopen MX46-533VII, SiS 651 Chipset, Phoenix/Award 6.00 PG BIOS. I want to install a video card, but I have to disable the onboard graphics to do it. I've uninstalled drivers and installed drivers for my new card and everything, but it doesn't work. I think there might be some switch or jumper that I'm missing, that turns off the onboard graphics. What do I need to look for?
shoib127300
  • 55 Answers
SOURCE: I lost my motherboard driver please send me a
Which driver for the motherboard are looking for???Is it for the chipset or for all the drivers..chipset,Audio,video,network etc???
Please click on the link below to find the drivers for ur system.
http://www.viaarena.com/default.aspx?PageID=2
Select the operating system from the list and there you go....
Posted on Mar 18, 2009
cowboytech
  • 69 Answers
SOURCE: Blue screen on start-up. Mobo SIS-741 Chipset SIS741GX Rev 03
This problem can be caused by several things. First, are the memory chips exactly identical (brand, type, size, etc.)? If not, that will definitely cause the problem. Second, how many memory slots are there? If you have four, check the manual and make sure you're putting the memory in the correct slots. Some Mobo's require that you put chips in slots A1 and B1 and not A1 and A2. Also, some Mobo's have DDR slots and DDR2 slots, so make sure you're putting the right kind of memory into the proper slots. Some people fudge the memory by putting 400 mhz memory into slower slots, and that works one chip at a time - but if you install a second, identical chip, the system will fail. If all else fails and you've met these conditions, check the type of memory to be sure of the proper fit (use manufacturer's recommended brands and numbers) or try a different chip in the second slot. One chip could be bad.
Posted on May 25, 2009
Morikvendi
  • 56 Answers
SOURCE: want to disable onboard graphics to install and use pci vga card
During the initial boot sequence (as soon as you turn your PC on), try pressing <DEL> button (or F2 or F10 - you will see info on the bottom of the screen stating something like "Press _____ (del, F2, F10) to go to Setup..."
This will take you to BIOS, main setup panel for your PC.
There you can find and option for switching your main GFX card.
Options will be something like: onboard, pci, agp. You should choose
PCI.
Try doing this after you insert your new PCI gfx in your computer.
Good luck,
Milan
Posted on Jun 01, 2009
  • 3 Answers
SOURCE: is visiontek a radeon hd 2400 pro agp 8 compatible w/ p4s800- mx?
ATI has recently written some better drivers for the 2400 Pro AGP cards,... Make sure the setting in the BIOS for the motherboard is set to the AGP or PCI for primary video. For AGP, make sure that you have the power from the power supply connected to the video card. Make sure that your motherboard does support 8X AGP video cards. If you are not sure, please check with motherboard manufacturer for compatibility.
Posted on Jun 05, 2009
  • 177 Answers
SOURCE: Everex GA3400 no video, no BIOS splash, nothing. Install PCI card
First look for a CMOS battery on the motherboard. If found, disconnect the battery and also disconnect the power cables from the system.
Wait for about 10 minutes and then reconnect battery.
Turn it on. If it remains same, try to re-seat memory modules and let me know if you get any beep sound when you turn on the system
Posted on Feb 18, 2010
Need the driver for aopen mx46-533gn vga driver
According to this website (http://www.motherboard.cz/mb/aopen/MX46-533GN.htm), your AOpen uses SiS as a chipset as well as its VGA.
If you use Windows OS, try to dowload and install this driver:
http://download.cnet.com/SiS-VGA-driver-3-78-00-zip/3000-2108_4-164001.html
or
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Sis-650-651-661-662-740-741-760-761-368-WHQL.shtml
I hope this solution might work. Thanks for using FixYa!
Jul 06, 2011 | Computers & Internet
Need VGA driver for- Aopen MX46-533GN (the number on the mother board )
or
Update for my BIOS... help me!!
Here is latest bios update for Aopen MX46 motherboard:
ftp://ftp.aopen.com/pub/bios/mx46/wmx46r112.zip
And this is the same old R1.12, because there is no newer update since 2002
Aug 22, 2009 | Computers & Internet
May 25, 2009 | SIS741GX-MN Motherboard
I lost my motherboard driver please send me a driver.... BIOS Type: Phoenix-Award BIOS Date: February 1st 2002 BIOS ID: 02/01/2002-P4X266-8233-JD6LWC2DC-00-None BIOS OEM: 02/01/2002 - 6.00 PG Chipset: VIA...
Mar 18, 2009 | Intel Computers & Internet
Comp will not recognize my agp radeon HD2400 pro graphics card
Try the following : Go into the setup routine using the onboard video. Go to the  Intergrated Peripherals.
Find the onboard video and change it to disable. Save changes.
Change monitor to the AGP card.
  I hope this helps.
Here is a web site for your Award Bios setup:
http://www.buildeasypc.com/sw/bios_setup.htm
Inegrated Peripherals
This menu allows you to change the various I/O devices such as IDE controllers, serial ports, parallel port, keyboard etc. You can make changes as necessary. See figure 5.
Dec 19, 2008 | Biostar P4M80-M4 Motherboard
Is visiontek a radeon hd 2400 pro agp 8 compatible w/ p4s800- mx?
Dec 13, 2008 | VisionTek ATI RADEON HD2400 Pro Edition...
Were are the jumpers to disable the on board videofor aopen mx3w pro-E
Why do you need to disable the onboard video??
If you have added a new graphics card it should automatically select this new card.
If it doesnt, you can go in to the bios and disable the onboard graphics card from there.
For example, Onboard graphics can usually be refered to in the bios as PCI, so if you've added an AGP card or PCI-E card then you would just need to select either one of these from the bios menu.
Not sure what bios your using but it may even have ann option to disable onboard graphics.
Oct 23, 2008 | AOpen MX3W Pro-E (91.88210.241)...
I have an acer aspire m1610, I'm desperately trying to disable the onboard video card in order to add a geforce 8500 but there's no way to disable the onboard video card via the bios and the computer wont...
Are You sure the graphics card is not defect?
When I installed a graphics card instead of the onboard
circuit, the SIS Mirage was disabeled automatically.
I have installation CD for the graphics, of course.
Also, I thought that disabeling devices could be done
through the control panel, "hardware devices".
Sep 13, 2008 | Acer Computers & Internet
Need help
You need to enter your motherboards bios. As the system starts up press the Delete key every two seconds. Hopefully you'll have video doing this. If you do not have video display. You'll have to remove the new video card for a short while. Again enter your bios. Still have your manual? If not click the link & download it here. http://www.foxconnchannel.com/EN-US/support/downloads.aspx?ProductModel=865G7MC-ES&TypeID=en-gb0000001
Enter Advanced Chipset Features
Goto pg. 33
On-Chip VGA (Default: Enabled). Disable this.
Init Display First (Default: Onboard/AGP) Change to AGP/Onboard. The AGP is to load first before the onboard.
Save & shut down the system. Clean out the AGP slot. There can be a dust build up from not using it. Canned air works well.
Leave the side case off untill your sure the 7600 is running correctly.
Get to know your board alittle. Read the manual a wee bit.
Good Luck! Enjoy!
please vote
Feb 15, 2008 | Foxconn (865G7MC-ES) Motherboard
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
