Question about GE 46GW945 46" Rear Projection Television
Just recently my GE 46GW 945 46 in. Rear Projection Television when turned on goes from a good picture to a sideways hour glass shape and an almost 3d like picture with the RED BLUE and GREEN..When I turn it off then on I get a good picture for about 30 seconds and then BANG hourglass.
  • 171 Answers
Sounds like convergence circuit has died.  time to call a tech..
Posted on Jul 28, 2010
Power button lights up but tv won't turn on
Older set but pretty good set, set is prone to the HV transformer going bad but not many other issues.
Sep 03, 2012 | GE 46GW 948 46" Rear Projection Television
I recently moved and apparently after I moved, I'm guessing that the projector moved and it looks blurry and double picture, how cam I fix this?
you might have a bad connection going to the convergence move , a connector might have came off. Or the cable that that you are using going to the set, is defective and needs to be replaced.
Nov 18, 2010 | GE 46GW 948 46" Rear Projection Television
Just recently my GE 46GW 948 46 in. Rear Projection Television when turned on goes from a good picture to an hour glass shape and an almost 3d like picture.When I turn it off then on I get a good picture...
Sounds like a loose solder connection on the Convergence board or the convergence power board. If you are savvy and electrically safe, tap on the boards with an insulated screwdriver to see which has the loose connection, and you can resolder to fix. Repair from a service center = $150-300
Jul 26, 2010 | GE 46GW 948 46" Rear Projection Television
Ge projection tv
can you hear the tv starting on or a noise from the back
it may be the trippler or the power supply
Jun 14, 2008 | GE 46GW 948 46" Rear Projection Television
Magnavox 51mp392h
replace the convergence ICs STK392-120 you will need both of them also check the 6.8 ohm resistors right next to the ICs as often 1 or 2 of them burn open. You should be able to notice the discoloration in the center of the resistors.
Mar 11, 2008 | Philips 60PP9202 60" Rear Projection...
Magnavox 51mp392h
Are your colors out of convergence also? If so this is a classic symptom of bad Convergence ICs.
Jan 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Zenith 50 In Rear Projection Hour Glass
My picture is a double image and has a sideways hourglass on the screen. Please help me!
Oct 08, 2007 | Zenith IQB50M90W 50" Rear Projection...
Hour glass as picture
It is possible that your television needs to be degaussed. Gaussing occurs in televisions that have magnets, (usually speakers) placed to close to the unit. A degaussing coil can be purchased at a good electronic supply store. Simply follow the instructions that come with it. If this does not fix the problem, the television will require repair by a qualified service center.
Jul 25, 2007 | Samsung PCL541R 54" Rear Projection...
Picture shaped like hour glass
You have a PIN CUSHION problem, is usually a bad capacitor or open resistor in the above cicuit. Check all the caps around the horizontal output transister for ESR leakage.
Jul 03, 2007 | Akai PT4298HD Rear Projection Television
Televison & Video Logo
74 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
