Hi, i have installed a grundfos upa 15/90 booster pump in my house, the pump housing faces upwards, is this a problem as the pump has now stopped working? i need an answer asap, many thanks.
Pump keeps blowing house fuse
It is likely that the shaft seal in the pump has failed and the water is leaking into the motor. Water and electrics = fuse blowing!!
Oct 12, 2013 | Grundfos MQ3-35 3/4 HP Pressure Booster...
I have low pressure at house, There is no problem
I am just guessing but it appears there is a restriction such as a partally closed valve.
Sep 01, 2013 | Grundfos Pumps Grunfos UP15-42F 1/25 HP...
Operating specs for Grundfos Model 96515513
HI THEIR MISS WILLIAMSON.. IS PUMP OPERATIONAL. IF SO THAN YOUR ANSWER IS YES. IT WOULD BE IN YOUR BESTS INTEREST TO HAVE A expansion tank. IN ORDER FOR YOUR SYSTEM TO RUN AFFECTIONATELY. NOW TO YOUR QUESTION ABOUT THE warranties ON A PRODUCT. THE warranties MOST PRODUCTS ARE NORMALLY ONE YEAR (1yr) FROM THE DAY OF PERCHES
Dec 29, 2011 | Grundfos MQ3-45 1 HP Pressure Booster...
I have had a Grundfos CME Booster pump installed for some ten months or so. We have a pump room alongside the 150,000 water tank. The inlet is suspended from a float within the water tank, and is about...
Hi Ray, did you ever solve your problem, I have a setup that sounds identical to yours and have the same problem, Grundfos are not been very helpful.
Oct 31, 2011 | Plumbing
I have installed a Grundfos CH2050PT pressure booster system at my home (3 stories). The pumps is installed at ground level and is connected to the main water tank (source of water). The pressure is...
it could be the differential in pressure between the cold water from your booster pump and the hot water from your solar water heater . the cold water which feeds your solar heater is probably being reduced in pressure by a pressure reducing valve . so what you need is equal pressure on both your hot and cold water system you could install a pressure reducing valve on the pipe thart feeds your cold taps etc valve set at the same pressure as the one on the solar water heater that would give you a balanced hot and cold water system
Dec 07, 2010 | Grundfos JPS4 1 HP Pressure Booster Pump
Grundfos submersible well pump with Grundfos CU301 control. Control box shows no contact to pump. What is the problem or problems?
Grundfos is a p. o. s. I have a new system cu 301 and I have had to get it repaired twice by Fogle Pump and Supply. These guys are real rip of artists in Washington State and should be reported to the BBB. Dont Use Fogle if you need a well
Sep 15, 2010 | Grundfos RCP-96 Recirculation Pump for...
I just bought a repo house which has a grundfos circulation pump u p 15 installed at the water heater. House built 2005 4260 sq. Feet. House has 4 showers only one of them gets hot water. All sinks get hot...
that pump is likely to be a hot water return pump not a booster pump. it sound like a large property so its likely the hot water system requires balancing to get the hot water to the extreme areas. If all the hot outlets have some form of isolation valve try closing all but the affected areas and see if hot water comes out. If so only open the closed outlets enough to give you reasonable flow. This hopefully will force the hot water to the affected areas.
May 20, 2010 | Home
House pressure water pump has to be reset to
it sounds like a relay for the auto shut off ....http://www.smarter.com/water-pumps/grundfos-mq3-35-3-4-hp-pressure/pd--ch-47--pi-11277834.html
Jan 16, 2010 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Leaks water out of the back
Well, I am no plumber but I would think that 108 psi is a bit high for your plumbing system. I have this pump installed in my house and have the max pressure set at 50 with a PRV on the outlet side of the pump.
Mar 24, 2009 | Grundfos MQ3-45 1 HP Pressure Booster...
Heating & Cooling Logo
686 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
