Question about AEG Lavamat 16810 Front Load Washer/Dryer
How do I clear stored error codes from an AEG 16830 washer dryer. Used the test procedure by holding down both left buttons and selecting a programme and got E72. Carried out a wiring repair which cured the dryer fault, just want to know if there is a sequence to clear the stored error code Kind Regards Richard
SOURCE: AEG Washer dryer will not complete cycle
I ended up trying the machine on a few different cycles all of which failed to complete. Finally tried a 'Drying' only cycle and it emptied out quite alot of water which was odd. It now seems fine. guessing it was a blockage and a certain amount of water was backed up in the machine??? any clarity welcome.
Posted on Mar 25, 2008
  • 44 Answers
SOURCE: AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Posted on Mar 21, 2009
SOURCE: My AEG Lavamat 16830 Washer Dryer does not heat up
Had an identical problem with my 16830 washer dryer and noticed reading other posts that others have had this issue with 16810 units too. After reading posts about the 'condensor issue' causing clothes not to dry properly I got a socket set and took the back-half cover off the machine (11 screws/hex screws in all) to have a look. I then removed and cleaned out the accumulated fluff from the transparent plastic condensor unit. It didn't appear to have much fluff caught within it so I doubted that this would solve the issue.
Upon putting the unit back into situ I noticed that the temperature sensor in the large black flexible tube that connects the condensor to the drum had just one orange wire attached to it. I then noticed a second orange wire hanging loose nearby and putting two and two together figured that the loose wire had dropped off the sensor. Since the connector can't be rewired I resorted to carefully soldering the loose wire to the connector and ty-rapped both orange wires to the connector to prevent the wires working loose again. Once I had the connector back on the sensor both wires were pretty taut between the main wiring loom and the sensor and so I suspect that what had happened was that in normal use the wire had come adrift from the connector due to the drum rocking back and forth and pulling the wires against the loom - a design flaw I'd say.
To create more slack for the two wires in question I cut the ty-rap holding the main wiring loom to the side of the dryer and then re-fitted a new ty-rap in exactly the same place around all the wires in the main loom except for the two orange wires so that they remained free of the main loom to move as the drum rocks. With the wire back in place and everthing re-assembled the dryer heats up perfectly and counts down as it should.
I figured that with the sensor not operating the computer determined incorrectly that the air leaving the drum was too hot/dry as would be the case if the contents of the drum were completely dry and as a result the computer turned off and kept off the heater for the remainder of the drying cycle. I also concluded that as an energy saving feature - with the computer thinking the clothes are dry - the dryer speeds up the remaining drying time so that the drying cycle finishes sooner, hence why the counter completes sooner than it should and all with no error message.
Hope this is of help to others.
Posted on Apr 01, 2010
SOURCE: the door handle of my AEG Lavamat turbo 16830 is
Hi there, we too have a similar problem. Our new door handle part has arrived but we are having huge problems fitting it as we cant prise the grey outer trim off the door and thus can't get in to put the new door handle in.
Please help! How can we get the trim off without resorting to serious damage with a screwdriver!!!?
Posted on Jan 23, 2011
  • 6277 Answers
SOURCE: Hi, My son has pulled an
As long as the hose still has its 'bung' in the end and it's not ripped or torn so that water does not come out, I cannot see the fact that it is 'very loose' affecting anything. You would have to pull it to gain access to the bung in an 'emergency and drain whatever water was left in it anyway ;-0)
Clever lad. Put him on FixYa to give advice on 'emergency emptying' !
Cheers, John C
Posted on Mar 18, 2011
My aeg lavatherm 56600 acts strangely. The timingclock seems to go too fast, and the waterpump rund continously Even when floatchamber is completely empty. Heating works seemingly perfect, and sensor brush...
It looks like that is not correct Conductivity sensor (two brushes; wiring and electronic). I'd like to know if you replaced the both carbon brush (6), which makes contact with the drum shaft is situated in the protective housing (7) of the drum shaft and carbon brush 3b.
25316337-hf2jxxovvq5cn05mugly0fcq-5-0.jpg The last alarm code memorized can be displayed even if the appliance is in normal operating mode (e.g. while the drying
programme is being performed):
- Press button start/pause and first nearest button simultaneously for at least 5 seconds: the display shows the last alarm. The alarm sequence continues to flash as long as the two buttons are held down.
The appliance continues the cycle while the alarm codes are being displayed. If the appliance is in programme selection mode, the options previously selected are stored in memory.
However, your tumble dryer is smart and if something is wrong it should be displayed by the alarm codes.
Dado
Dec 10, 2014 | AEG Dryers
Aeg 72630 update
Press first left up button and first left down button simultaneously
( during the execution of the washing programme ) for at least 2 seconds: the LED switch off and then display the sequence of flashes indicating the alarm.
The alarm sequence is displayed for the time in which the buttons are hold down.
When you read the alarm code,we will be able assume what may be faulty.
Dado
Aug 31, 2014 | AEG Washing Machines
Aeg lavamat turbo 16830
start at the beginning,, check your fuse
Jul 16, 2013 | Washing Machines
I have an AEG Electrolux 16830 - I get an error code E10 - pressing the start switch recommences the program and it completes as normal. How do I reset the machine so this does not happen. An engineer...
E10 indicates that the water inlet hose is squashed or kinked.
First check the filter for coins or other junks.
Make sure the drain hose isn't blocked, restricted or kinked.
Hope this helps.. Good luck! ;)
Thanks for using
FixYa - a 4-thumbs up rating is greatly appreciated for answering your free question
Jun 06, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16830 washer dryer
can anyone tell me how to remove the rear panel of a AEG lavamat dryer. regards Roy
Jul 20, 2008 | Washing Machines
Mar 24, 2008 | AEG Washing Machines
AEG Lavamat 16810 Front Load Washer/Dryer Logo
199 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
