Question about Canon CLC 1120 Color Copier
Paper jams The paper jams instantly. Every time
    New Friend:
Http://ulozto.cz/xYq4n9Dp/clc-1120-service-information-pdf
http://ulozto.cz/xmTxQqcE/clc-1120-service-manual-pdf
Posted on Mar 16, 2014
  • RooTy CZ
    RooTy CZ Apr 22, 2014
    service manual and service information in PDF -- (English lang)
  • 1,219 Answers
first try to clean paper feed rollers in cass.
Posted on Jul 29, 2010
Where does the latch lever go on a HP Officejet 5610
Call HP support Toll free number 1-888-687-4491 (USA) AND FIND instant help for Paper jam issue by experts hp technicians.
Mar 13, 2018 | HP Office Equipment & Supplies
Canon pixma says there is a paper jam. Orange blink x2. No paper jam found. What else can I do?
Please check for dust or any kind of dirt in the printer....the sensor might be detecting it and thinking it might be a paper
Mar 12, 2017 | Canon Office Equipment & Supplies
How to clear a paper jam in my printer?
  1. Turn off the machine, and unplug the power cord of the machine from the power supply.
  2. Open the paper output cover. ...
  3. Make sure that the jammed paper is not under the FINE cartridge holder. ...
  4. Hold the jammed paper with your hands.
  5. Pull the paper slowly not to tear it, then pull the paper out.
to know info SAF 2507 pipe fittings
May 20, 2016 | HP PSC 950 All-In-One InkJet Printer
My printer is showing an error code 3524 (paper jam) yet there is no paper jammed. It says press OK to continue, but just instantly returns to the same message. It does seem that the cartridge head is
had the same problem it only happened when i turned the ac off . humidity i guess. i started buying paper made for a inkjet cost a little more but it seems like it helping.
Oct 24, 2014 | Kodak ESP C310 AllInOne InkJet Printer
Paper jam displayed but no paper jam found. Cleaned with air but this did not help. Seems like printer wants to keep resetting itself.
I had this problem and someone on Fixya solved it. Open the back cover and slide the guide slightly. If it's off center it won't work and gives you the jam message even though there's no jam. It solved it instantly.
Sep 27, 2011 | Brother MFC-7820N Printer
My kodak All-in-one printer ESP9 goes instantly in paper jam. Checked for a paper jam and found no paper jam or any paper anywhere inside machine. Pressed down on "OK" button and printer...
Had same issue with my ESP 9, called up the kodak support lines and spoke to them over the phone, getting a replacement sent out free of charge and I've owned this for 1 year and 4 months and only had one prior printer jam which righted itself in the past. Seems like ESP 9's are prone to the unfixable printer jam.
Best bet call kodak and get it sorted.
Jan 12, 2011 | Kodak Office Equipment & Supplies
CANNON IR2016R WHEN I START AFTER INITIALIZING IT
7.2 Detecting Jams 7.2.1 Delay Jams 7.2.1.1 Delay Jam in Pickup Assembly 0010-4883 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Delay Jam in Pickup Assembly The registration sensor cannot detect the leading edge of paper within the jam detection time interval after paper pickup started. T-7-2 7.2.1.2 Delay Jam in Delivery Assembly (Paper Leading Edge Jam at First Delivery Sensor/Wound Paper Jam at Fixing Assembly) 0011-0712 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Leading Edge Jam at First Delivery Sensor The first delivery sensor cannot detect presence of paper within the prescribed time after the registration clutch has been turned on. T-7-3 Wound Paper Jam at Fuser The first delivery sensor has detected absence of paper within the prescribed time after it detected presence of paper (within the prescribed time after the registration clutch had been turned on). T-7-4 7.2.2 Stationary Jams 7.2.2.1 Stationary Jam in Pickup Assembly 0010-4884 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Stationary Jam in Pickup Assembly The registration sensor does not detect absence of paper within the prescribed time before the next leading edge of fed paper reaches the registration sensor. T-7-5 7.2.2.2 Stationary Jam in Delivery Assembly (Paper Trailing Edge Stationary Jam at First Delivery Sensor/Stationary Jam at First Delivery Sensor) 0011-0733 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Trailing Edge Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after the registration sensor has been turned off. T-7-6 Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after it has detected the leading edge of paper. T-7-7 7.2.3 Other Jams 7.2.3.1 Door Open Jam 0010-4886 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Door Open Jam The door is opened when paper to be printed is in the paper feed path. 7.3 Cassette Pick-Up Unit 7.3.1 Overview 0010-4887 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i The paper picked up from the cassette is fed to the registration roller using the vertical path roller driven by the main motor (M204). The registration roller is not rotating when paper reaches there, so an arch is formed at the leading of the paper to prevent skewing. The DC controller PCB turns on the registration clutch (CL203) at the prescribed timing to transfer the main motor rotation to the registration roller, thus feeding the paper to the delivery tray through the transfer, sepa- Sensor/Solenoid Registration sensor (SR209) Pickup solenoid (SL202) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203
Jan 04, 2010 | Canon iR 2016i Black and White Copier
I have unjammed printer - still says that there is a paper jam
If you have removed all drums, fuser, transport belt, cassette and duplexer if fitted and ensured there is no paper, and turned off and on printer whilst disconnected from pc, and it still instantly comes up with a jam, then I'll tell you where it is... open front cover, in center,front.. there is a cover a little bigger than match box, it clicks off, under here is your jammed sheet , people tend to just rip out the jam, and leave behind a small section of the paper, that you cant see, unless you look very carefully or remove little cover to expose it.
Jan 13, 2009 | OKI C5100n Laser Printer
My printer says I have jammed paper, but i cannot see the paper. How do I fix this?
without knowing the make and model of the printer, it is hard to answer this question.
a paper jam is detected by a printer in one of two ways. Either paper has not reached a sensor in the time it should have, or a sensor is blocked when it should not yet be.
Several things can cause this, one of which would be obvious, in that paper is actually jammed and blocking a sensor that should be open.
Another cause is that paper has not reached a sensor in time. This can be caused when a pickup roller is worn, and not actually pulling paper from the tray, so it sounds like it is working, but there is no paper to print on.
and finally another cause is a broken or malfuntioning sensor. In this case, you will not find any paper blocking a sensor, and is usually an instant failure when the unit is turned on it will automatically error out with a paper jam error. In my experiance, this is usually a broken paper exit flag on the fuser, caused by a paper jam being removed by pulling the paper out of the fuser backwards and breaking the flag.
Sep 22, 2008 | Office Equipment & Supplies
Canon CLC 1120 Color Copier Logo
136 people viewed this question
old marine
old marine
