Question about LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T...
Light bulbs are so hot they are melting the plastic in the case
2 Suggested Answers
  • 161 Answers
SOURCE: The light bulbs inside my
You have a bad main board with a relay stuck shut. Call an LG dealer and ask them if there is a service bulliten on your model. If there is, your parts are free.
Posted on Jan 22, 2010
Testimonial: "This is exactly right. Both the parts and labor were covered by LG, even though the fridge is almost 3 years old."
Volvo v70 head light bulbs gets too hot melts plastic connector/why
check that the connection on the headlight is tight if loose can spark causing bulbs to get hot and melts the plastic
May 18, 2014 | Volvo V70 Cars & Trucks
Tip
Reduce risk of overheating and plastic melting if lights stay on
Even though I have found a statement (I think it was in the LG2.gif troubleshooting2.gif FAQS on line) that the lights in the newer LFX25960 french door/bottom freezer refrigerator will shut off after a period of time to prevent overheating and melting the plastic housing, I have heard of this problem enough times to worry about it. So I replaced the two 60 watt bulbs in my refrigerator with 25 watt appliance bulbs just in case. They provide more than enough light and do not get as hot when on. It took a while to find them. They are made by Philips2.gif and were at Home Depot but not always in stock.
on Sep 18, 2009 | LG LFX25960ST Stainless Steel French Door...
2003 durango brake light not working
If only one brake light is out (mine was driver's side) and you've tried changing the bulb, then it might be a metal contact in the bulb socket in the light assembly. Looks like the hot bulb melts the plastic and lets the one or more bulb contacts sink into the socket and pull away from the base of the bulb, preventing electrical contact. A little coating of solder on the socket contact(s) gave enough height to contact the base of the new bulb and get the brake light working again.
Feb 10, 2013 | 2003 Dodge Durango
Melting turn signal bulb
If the contacts get hot, There is a broken wire ,Or woires that are shorting out,
Nov 05, 2012 | 1998 Buick Century
LIGHTS STAY ON IN FRIDGE
LG had a problem with the control board going bad allowing the interior lights to stay on even when doors are closed. you need to get in touch with LG concerning repair MY UNDERSTANDING is there is a safety recall and it will be repaired for free. in the mean time unsrew the light bulbs so they dont melt down your liner...
Oct 03, 2012 | LG Refrigerators
Elite trio, 795.755 Refrigerator light stays on, getting hot. Refrigerator space warming up to 45 degrees. Pressing in both door switches gives no clue. Both feel smooth.
Some of these Kenmore Elite refrigerators built by LG have a design defect that has been the subject of a class action settlement. The interior lights stay on even if the doors are shut, turning the refrigerator interior into a version of the child's Easy Bake oven toy. There are many cases where plastic interior parts of the refrigerator got so hot they melted. I replaced the 60W incandescent bulbs with 7 Watt LED bulbs just in case. The LED bulbs will not get hot enough to harm anything even if left on indefinitely.
This model also has problems with the wires inside the door (water dispenser side) The wires break inside the door and are not replaceable. I ran new wires through the interior and bypassed the broken wires to avoid buying a whole new door.
May 21, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Light remains on when fridge door closed. door switch does not turn lights off? light was hot enough to melt plastic cover
You can take the door switch out and replace it with a new one. You may also need to get an appliance light bulb that's not so hot.
Oct 10, 2009 | LG LRFC25750 French Door Refrigerator
Brake light melting
I never heard of this problem,If I were you i would get another one from the junk yard and see what happens.It probably will work,sometimes things are defective and they don't get found until a person like you has the problem.Good Luck!
Jul 23, 2009 | 1999 Chevrolet Venture
Light bulb in new bottom freezer model
Maybe the little man inside that shuts it off is on vacation. Just kidding! With the door open, look for a little trigger/switch that shuts the light off when you close the door, press it and see if the light goes out. Out of curiosity, what wattage bulb do you have in there that would melt the cover. It should be no larger than 40w, 25w being the best.
Nov 13, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T... Logo
268 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
