Question about JUMP START SYSTEM
Vector jump starter displays error F03
Vector VECO12B Jump starter has error F03. Will not re-charge itself. No longer have manual to know what this error means but assume the battery will no longer take a charge?
  • 10,314 Answers
Http://www.baccusglobal.com/bd/manuals/NEW%20MANUALS%20FOR%20WEB/VEC012POB%20MANUAL.pdf
Posted on Jan 23, 2014
5 Suggested Answers
SOURCE: lost the 12-volt DC charging cord for my vector jump starter
google the name and model #. The home website should come up in search. Go to site, and look in support, or replacement parts.
Posted on Aug 23, 2009
  • 3 Answers
SOURCE: I need to replace the ac adapter for my vector
http://www.stylefeeder.com/i/6sr4398f/Black-Amp-Decker-5140045-42-Replacement-A-C-Charger
Posted on Dec 13, 2009
  • 4 Answers
SOURCE: I need a vector jump starter ac adapter. Lost
Radio Shack
Posted on Jul 10, 2010
miket756
  • 2702 Answers
SOURCE: My vector jump start system
yes there is but its very pricy,,,you may find its cheaper to buy a new jump start pack,,
as its broken you wont loos anything if you took the battery out and hooked it up to a small battery charger say 2amps and recharged it that way,,,,
at a C10 rate! ==20ah battery --2ah hour charge ==10hours to fully recharge the battery
i hope this helps you out,,,,
Posted on Nov 28, 2010
Can I charge my battery in the house using a vector jump starter
Advisable to have a well ventilated space because hydrogen could build up and explode. >> http://mechanics.stackexchange.com/questions/2810/what-precautions-are-needed-when-charging-a-car-battery-in-an-apartment
Oct 11, 2014 | Vehicle Parts & Accessories
Need charger power cord for vector 450 jump start
UpBright AC Adapter Charger For Vector 450 Amp Jump Start System...
This is a generic charger cord listed by Amazon specifically for the Vector 450 Jump Starter.
Jul 07, 2014 | JUMP START SYSTEM
REPLACEMENT BATTERY VECTOR JUMP STARTER
Ebay lists over 150 of them. 12v 19ah will get you to a seller.
The jump starter won't have a problem with the extra ah capacity but there might be a problem with the physical size of the battery.
The jump starter's charge function may work a little harder though.
Oct 01, 2012 | JUMP START SYSTEM
On vector jump starter 400, what will the display state when fully charged?
THERE SHOULD BE A BUTTON ON IT TO CHECK CHARGE STATUS.
Jul 24, 2012 | JUMP START SYSTEM
How do you recharge the vector? Don Rutledge
VECTOR VECO12B, JUMP´N CHARGE SMART BATTERY CHARGER.
Hola a todos, yo he comprado recientemente (Febrero 2011) este sistema. Yo he tenido el mismo problema el cual no carga la bater?a interna del sistema. El sistema de carga de bater?as funciona bien pero el sistema de jump-starter no funciona.
Luego de hacer varias pruebas, de leer en internet y analizar el problema, yo llegu? a la conclusi?n de que la bater?a interna esta da?ada o fuera de especificaci?n.
Que sucede? Lo que pasa es que la bater?a interna del jump-starter se encuentra en un nivel de tensi?n (Voltios) se encuentra demasiado baja, lo cual no es suficiente para que el cargador lo vea como suficiente para iniciar la carga, muestra la falla F01 o F02.
Lo que yo realice fue lo siguiente: usando el cable de carga de 12 volt DC, yo coloque un extremo conectado al salida de 12 volt DC desde jump-starter y el otro extremo del cable yo lo conect? con los cables auxiliares a una bater?a externa. Esto hace que se conecte la bater?a interna del jump-starter, con la bateria externa. Esto sin usar los cables de pinzas para bater?as.
Bajo esta condici?n yo conect? el jump-starter a una toma de 110 volts AC y yo lo encend? y luego yo seleccion? el nivel de carga (2, 4 o 6 Amps). El cargador inici? la carga de las dos baterias, (la bateria interna del jump-starter y la externa).
Esto hace que la corriente de carga se distribuya equitativamente (dependiendo de la impedancia de cada bater?a) entre las dos bater?as.
Yo lo deje en esa condici?n por 12 horas, siempre chequeando la condici?n del sistema.
Luego de ese tiempo, yo desconect? el sistema y yo medi en el socket de 12 volt DC, la bater?a interna y subi? a un nivel de 11,50 volts DC. Desde ese momento el jump-starter, comenz? a reconocer la bater?a interna como buena, y yo lo deje dos horas carg?ndose a si mismo, y luego de esto, el nivel de tensi?n era de 14,40 volts DC.
Yo apagu? el cargador y el sistema quedo cargado dispuesto para trabajar.
De todo esto yo deduzco que el problema era la bater?a interna la que no tenia suficiente nivel el?ctrico para que iniciara el cargador de baterias su trabajo.
Saludos, yo espero que esto le sea de ayuda para todos.
Ali, desde Venezuela.
alilo07@hotmail.com.
Electronic translate
VECTOR VECO12B, Jump'n CHARGE SMART BATTERY CHARGER.
Hello everyone, I recently purchased (February 2011) this system. I have had the same problem which does not charge the internal battery system. The battery charging system works fine but the jump-starter system does not work.
After various tests, online reading and analyzing the problem, I came to the conclusion that the internal battery is damaged or out of specification.
What happens? What happens is that the internal battery jump-starter is in a voltage (V) is too low, which is not enough for the charger to see it as sufficient to start charging, it displays the fault F01 or F02.
What I made was this: using the power load of 12 volt DC, I placed one end connected to 12 volt DC output from jump-starter and the other end I connected with the auxiliary cable to an external battery . This makes connecting the internal battery jump-starter, with the external battery. This without using the battery cable clamps.
Under this condition I connect the jump-starter to a power of 110 volts AC and I turned it on and then I select the level of charge (2, 4 or 6 amps). The charger begins charging the two batteries (internal battery jump-starter and external).
This makes the load current is distributed equally (depending on the impedance of each battery) between the two batteries.
I leave it in that condition for 12 hours, always checking the condition of the system.
After that time, I disconnect the system and I measurement in the 12-volt DC socket, the internal battery and up to a level of 11.50 volts DC. Since then the jump-starter, began to recognize the internal battery as well, and I leave two hours charging himself, and after that, the level of tension was of 14.40 volts DC.
I turned off the charger and the system is loaded ready for work.
From all this I deduce that the problem was the internal battery which did not have enough power level to initiate the battery charger work.
Greetings, I hope this is helpful for everyone.
Ali, from Venezuela.
Jan 30, 2011 | JUMP START SYSTEM
My vector start-it elite jump starter is not holding charge even after days of charging. Why?
Hi Ydja,
The batteries on these jump boxes don't last very long. I've been through three of them. Never again.
Now I just carry an extra battery. It's more powerful and has laste longer than the three jump boxes put together.
Best regards
Mike
Dec 12, 2009 | Vector VEC010S Jump Start System 300 Amp...
Lost the 12-volt DC charging cord for my vector jump starter
Aug 23, 2009 | JUMP START SYSTEM
How do you get the Jump'n Charge recharged?
It should take a charge from any outlet, if not it's not working properly:
Built in Automatic 110/120 volt AC adapter
Digital display shows charge rate, operating mode, fault codes and FUL when charged
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
May 27, 2009 | JUMP START SYSTEM
Instructions on AC Chargeing Vector Jump Start 12 volt
When charging the jump starter , should the switch be on or off .
Mar 30, 2009 | JUMP START SYSTEM
JUMP START SYSTEM Logo
246 people viewed this question
Top Vector Vehicle Parts & Accessories Experts
Lawrence Oravetz
Vernon Taylor
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
