Question about Panasonic KX-TD7895 Cordless Phone
KX-TD7895 problem This phone gets no dial tone and doesn't respond when the locator button is pushed. It doesn't ring during an incoming call. The phone line works fine.  I tested the battery by switching one from an identical phone and it still wouldn't work.
  • 106 Answers
If you were using this unit and it was functioning, then most likely the handset has gotten damaged, and you would need to send the handset and base into repair (its not programming setting or a field servicable problem). If your testing this unit for the first time, the base may not "match" the handset. You can tell if they match by looking at the code on the little white sticker on the bottom of the base, and it must match the code on the sticker on the handset which is under the battery. So if they match, and they still will not communicate with eachother not much can be done until its put on a diagnostics and testing. You can google kx-td7895 repair to find a facility. Good luck
Posted on May 02, 2009
How do I program different ring tones for the KX T7220. THere are 6 to choose from I believe.
1 Press program key
2 Dial 99
3 Press line key or intercom key twice
4 Dial 1-8 for tone type
5 Phone will ring with new tone
6 Press store button(autodial)
7 Press program key to end
Dec 07, 2010 | Panasonic KX T7220 Corded Phone
How to recieve a fax on the Canon PIXMA MX340 Wireless Office All-in-One Printer
Take your incoming phone line and plug it into the place that says "line" on your fax machine. Plug another phone cord into where it says "phone" and connect this to your telephone. Test to make sure you have chosen the right places by dialing a phone number to fax to and listen for the dial tone. If you get a dial tone, then you have set it up correctly.
On the fax machine look for the button that says "menu". Push it and use the up and down arrows to navigate the options on the display. Look for fax set up and press "ok" or "enter" on the fax machines keyboard to access this area. Look for "number of rings" and change the fax machine to a number of rings that is less then your voice mail box if you have one. Then close and save your choices.
Have someone send a test fax by dialing your phone number for the line connected to the machine. The fax machine will pick up on the number of rings set and automatically begin receiving and printing a copy of your incoming fax.
You cannot use magic jack.
You can also choose to manually answer an incoming fax if you see that your display on the fax machine says "ringing" or incoming" you can push the "start" button and this will start receiving your incoming fax.
Sep 30, 2010 | Canon imageCLASS MF7480 Laser Printer
Phone won't transfer to next free line when a second call comes
If you are not getting a dial tone then something is holding the line off hook. Disconnect any other device you have on your lines and check to see if you get your dial tone back. If you still have no dial tone unplug each phone and check again. You may have to disconnect everything for a minute or two so the phone company will reset its equipment. Plug in your phones one at a time and check your dial tone every time you add something new.
If you add something and you loose your dial tone immediately you may have a crossed connection in the wall socket, any splitters or in the phone plug. Check to make sure all of the wires in those sockets are straight before you plug in your phone wire.
If you add your CC machine and everything is good but it fails after you run a transaction you will have to contact the supplier of your CC machine. It is not hanging up the line.
Mar 22, 2010 | Panasonic KX-T7730 Corded Phone
Panasonic kx-TG2352 can not dial ,phone works for
Believe it or not, I accidentally discovered you have to really press hard on the numbers to dial !!! I guess this happened as one is used to a light touch working on a cell etc
Nov 30, 2009 | Panasonic KX-TG2352 Cordless Phone
My phone is not ringing on incoming calls
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Jul 15, 2008 | Nokia 1600 Cellular Phone
Panasonic cordless phone KX-TG6052
reset the dial mode if it is on tone and you have pulse it will not dial out.
Feb 08, 2008 | Panasonic KX-TG6052B Phone
Unable to dial out, check voice mail and see call display
Hi at the back of the phone you will see a selectable Hi/Lo/Off switch. Slide the (Ringer) switch to High position or Low position to turn the ringer on. Hi for high volume Lo for low volume.
To prevent hearing any ringing of incoming calls slide the (ringer) switch to the off position but when you ready to accept incoming calls again remember to slide the switch back to either Hi or Low setting. Hope this made sense and helped.
Oct 24, 2007 | Curtis Trimline TID582 Corded Phone
Panasonic KX-TD7895 Cordless Phone Logo
224 people viewed this question
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
