Insert new drive into my hp - Computers & Internet
    Scholar:
  • 103 Answers
What kind of drive and what are you trying to do?
Posted on Apr 23, 2008
Backup tape(RDX) getting ejected automatically after sometime while backup job is not running.
RDX tape drives, by HP (tandenberg)
did you reload all that HP software and drivers fresh?
did you try fresh tape.
i replace the tape drive, (new , used, NOS , from whom, ebay)
i bet the tape drive, logs errors, if you look,
the driver software will log that, and you can see why the tape
failed, my guess, damage to the tape, end to end.
try fresh new tape, NEW in a box, not used.
Oct 13, 2017 | HP Computers & Internet
Bios update version for hp a1420n
keep the flash drive in hand. try to install xp. while install it was asking for bios update and ask for press f8 for bios update and insert pen drive and select the path it will automatically update the bios and start installing
Apr 03, 2012 | HP Pavilion a1420n PC Desktop
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
Dont work and dont format
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved. Cause, there is damage to the partition table
Solution:
1. Save the data. To saved data, you can use EASEUS Data Recovery software.
2. After the data is saved, to fix the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system
Win XP: double click the file cp006049.exe - select Install
Win Vista & 7: double click the file cp006049.exe - select extrack
How to use the software HP Drive Key Boot Utility
For
Win XP, first way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For
Win XP, second way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7
, first way:
Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way:
double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
Hope it helps
Sep 06, 2011 | Kingston Technologies 512MB DataTraveler I...
How to install windows xp on a totally brand new hp mini laptop
Hi, you have to have an external drive / USB since HP minies does not have CD Drive, if u already have the cd installer of the XP operating system, just connect the USB / external drive to the computer then insert the cd installer, then follow the prompt on the screen on how to install the system, should be licensed installer with product key. If you have saved the installer in a flash drive, just insert the flash drive and install, no need for cd.
Thank you.
May 25, 2011 | HP Mini 1000 XP Notebook
I bought new hp usb flash drive 4 gb when i go to
you can try getting a flash for your bios to see bigger drives it is probably a size limitation in bios what operating system are using and how old is the computer
May 09, 2010 | HP 16 GB USB FLASH DRIVE PRO FULL SPEED...
I had to replace the original dvd drive on my hp dv6607 laptop. The new drive is brand new and installed. When powered up it spins for a while and the stops. Do i need to delete the old hp dvd drivers and...
turn it off, and flip it over and theres a one screw in the center, just remove that and then straightnen out a paper clip and push it in the hole on the front of the cd tray, you will see the small hole, just insert the paper clip and push, the tray will open, then you can just pull the cdrom drive out, then just insert the new one and put the screw back in. Thats it.
Later,
John Edwards
Nov 21, 2009 | HP Pavilion dv6000z Notebook
Dvd 740b not reading blank discs to burn on
NO PC stated dang. laptop or desk?
internal DVD drive or external HP solds all 3.
NO OS stated. windows? Windows what>?????
no real DVD partnumber stated only the usless
front bezel number 740.
if yours is marked 2001,, its going to be a big problem. 9 years past HP support.
and all old drive are weak now or scratched optics.
and drives that old were even full of bugs then
(we an link you to 10,000 pages showing that)
why not upgrade it.?
get a new drive and new fresher OS.
windows 10
and a nice new blu-ray burner.
and move on.
or if this rig (PC)
is 2001 why not go to GOODWILL
and buy a 2010 PC< for like $25
and i bet it works 10x better.
Mar 18, 2017 | HP dvd740i DVD±RW Dual Layer Burner
Cannot get HP Pavilion Entertainment PC to read a CD
Access the Hp.com website - you'll find a firmware update there for your dvd drive or if under warranty get a new dvd drive fitted.
Dec 27, 2008 | HP Pavilion DV5234US Notebook Laptop
Problem with my hp Dat 160 usb backup tape drive
make sure your backup server is not preventing the media being removed
try rebooting your server, if the tape then can be ejected it is probably your backup software.
If the tape wont eject even after both server and drive have been rebooted it is probably faulty and needs to go for warranty exchange with HP
Jul 30, 2008 | HP (C1530B) DAT Tape Drive
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
