Question about Home
My shower runs to hot and i cant turn it down
  • 909 Answers
The water pressure is too low, turn the stop **** up a quarter turn at a time until the temperature becomes adjustable as before.
Posted on Jul 28, 2010
Shower takes too long to get hot then runs lukewarm then hot lukewarm then gets cooler & and cooler &cold
There is a temperature adjustment on the hot water tank.
Perhaps it is set too low. They are often red in color.
Feb 24, 2016 | Home
Water leak behind shower wall when i turn on hot and cold water
If it only happens when you turn the water to the shower on, it must be a problem with the piping after the valve. Take the shower arm out and wrap it with Teflon, it could be as simple as leaking threads. It could also be a leaking/poorly soldered copper fitting, or even a defect in the enclosure itself.
Feb 27, 2014 | Home
Hot water at showers is intermitent while shower is on
http://waterheatertimer.org/Water-heater-recirculation-system.html
http://waterheatertimer.org/Crossover.html
Set timer so pump is off when shower time arrives
Check for crossover
Check if installation is correct... is the crossover valve installed correctly?
Gene
Feb 02, 2012 | Grundfos Comfort System Recirculator ...
I have two vanities and a shower in the bathroom. We only get hot water to the sinks when we turn on the shower to hot. Even if we turn off the shower we will still get hot water for a while. It just seems...
Check the water supply lines to the shower at the faucet handles. If the fitting for the hot water line connected to the handle is loose, it can twist and kink off the water supply further down the line when you turn the faucet handle. I'm not exactly sure how this could be relevant otherwise, but under normal design circumstances this type of scenario with your shower wouldn't matter for other faucets.
May 01, 2011 | Delta Faucet Bathroom Faucet - Delta 2...
Hello, I am putting in a grohe 35016 rough in valve. My shower has cold/hot 1/2" pex line coming in and i need to have one line going up into the ceiling for a rain shower head and another line going...
Hook the cold line up to right side and hot to left. Run line to wall shower off the top and use two 90 degree elbows with a short length of pipe turned slightly to the side of the line to wall shower. Run pipe up to ceiling height then 90 over and down to location you want forrain shower head. Hope I made this clear as I know sometimes I don't explain things well. Thank you.
Feb 04, 2011 | Home
My shower ok for mins, then cold, then after 5 min too hot
replace your mixet stem it is located behind the knob where you adjust your hot and cold water you will have to turn your water main off then you will need a flat head screw driver a phillips screw driver a pair of needlenose pliars to pull it apart
Mar 11, 2010 | Delta & Single Handle Shower Faucet
Hot and cold oscillations on my deva envy shower
no man i installed plenty of shower valves if your in the shower looking at it the left is hot always just make sure ur holding it right side up most of them have a plug that goes in the bottom to block the tub spout and the top goes to the shower are maby u put it in upside down? good luck man if you run in to another prob, post again good luck
Apr 11, 2009 | Plumbing
Replaced a moen cartidge and now the water is not hot in shower
make sure when you turn on the hot and cold shut off valves all the way and turn the moen on after that. Some times I would get that problem if I turned one(either hot or cold) off then tried the shower.
Feb 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Not enough hot water, has to do with a shower valve
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Home Logo
53 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
