Hi I have a GBC Creative Laminator A4 I have had no problem But last night the page got stuck, I turned it off and thought I would unscrew it and remove the page this morning BUT find I cannot unscrew it. The page is quite crumpled, I am not sure whether I should turn it on again or try to pull it back (I don't think it will anyway OR what to do. Can you offer any suggestions please? Ta Judy
  • 18 Answers
SOURCE: Hi, Our Ibico IL19VT Laminator (A2)
You can open this yourself but i recommend sending it for repair. If you decide to do it yourself here is how: turn the unit over and on the end with only one screw (not the power setting side) take it out using a Philips screwdriver. Next you will need size 3 and 4 hex bits. Use size 4 to undo the 4 hex screws. Hold the non power end and it should slide off. You will see four rollers two on each side of the heater element. Using the size 3 hex bit undo the 4 hex screws at the exposed end and lift up and out the 2 housing bits. Careful as these are made of plastic and break easy. Remove the offending material and then put everything back together.
Simples!
Posted on Jan 14, 2011
SOURCE: Rio Forge won't turn back on
pull the battery out for 20 minutes abd that is suppose to reset it
Posted on Jan 31, 2007
SOURCE: My Creative Zen Mozaic 4GB won't turn on
Use the reset button located on the left side. Worked for me!
Posted on Mar 02, 2009
goalie39
  • 469 Answers
SOURCE: Paper getting stuck in machine.
When the jam occurs, is the lead edge of the paper damaged?
Does it look like it collided with something?
If so, open up the machine to expose the paper path, (You may have to remove the drum unit) and manually feed the paper into the machine to see if you can detect what it is running into.
As it should line up with the damage.
Check the placement and alignment of the paper tray, if one end is higher than the other ot could skew and jam.
Check for bottom of drum unit for springs or flaps hanging down.
Check sensors, clean and operational? (Moving Type)
Blow out machine, clean rollers with alcohol.
Hope this is of some help.
Ed
Posted on May 09, 2009
SOURCE: GBC Eagle 35 Laminator heats up, won't turn
if you cannot get this fixed....i will buy it for spare parts.....408-802-3843
regards Cliff
Posted on Mar 15, 2010
My gbc heatseal laminator is rolling back and foward continuosly .even when reverse botton is not press. why
Can be for two reasons.
The synchronous motor in it is faulty, or there is something wrapped against the roller and it is lifting the spring or throwing it into reverse.
Contact GBC direct
GBC heatseal laminator Google Search
Sep 01, 2017 | Gbc Office Equipment & Supplies
Why is my GBC Ultima laminator beeping?
It will beep when you turn it on to acknowledge power. It will also beep when it reaches ready condition. Your laminator has safety switches for the lower feed tray and upper heat shield. Any time the upper shield is lifted the power is shut off. When you lower it down the power is turned back on, causing a beep. The same is true for the lower feed table. When it is removed and then re installed the machine beeps. These are safety features so that the laminator doesn't turn on when you are reloading it or unjamming it. Check that the safety switches are fully engaged if you get unnecessary beeping.
Oct 25, 2016 | Gbc Office Equipment & Supplies
My GBC ultima 65 laminator is making loud noises. How do i fix this?
You probably have 1 or more heat roller bearings seizing up. This is a common problem. There are 2 on the left and 2 on the right. I would recommend changing both of the bearings on the side that is noisy. They can eventually stop turning and then your laminator will probably stop also.
Aug 10, 2015 | Gbc Office Equipment & Supplies
My document has jammed inside the laminator. How do I remove the jammed document?
it is not possible to give advice or answers when you simply make unrelated statements...
Oct 27, 2014 | Gbc Creative 9 Laminator
How do I remove the back of my GBC laminator to remove paper that is stuck inside the unit?
First, you must take out 4 screws out of the cover on each side of the laminator , then you will see the screws that hold the back panel onto the laminator. West Laminating secs 405-324-6092
Oct 14, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Why won't someone answer the ??s about the GBC Pinnacle 27 power light in the back works, but no power
Each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime......
Westco Laminating Service 405-324-6092
Aug 09, 2014 | Gbc 1701720: Pinnacle 27 EZload Laminator
My gbc creative laminator won't heat up
We have an Ulitma 65 and it won't heat up...Any suggestions on how to fix this? We are at a school and no $ to replace the whole unit. Thanks in advance.
Mar 29, 2013 | Office Equipment & Supplies
Some one at work tried to laminate a card. when it did not come out she put in another sleeve thinking it would push the other out. smart uh! how do we get the 2 pages out?
If you were using GBC brand laminating pouches they don't need a carrier, if you were using another brand of laminating pouches, then a carrier is needed (something they don't clearly specify) and that's why the laminating pouch got stuck.
If you have had the laminator under a year, it should be under warranty, and you can call the company, and they will send a replacement, and they will probably then inform you of the above listed laminating pouch issue.
You may also want to try using the reverse button, but many times the pouches will get stuck between several rollers, and you risk destruction of the entire machine by attempting to take them out manually.
May 31, 2011 | Gbc HeatSeal H425 Laminator
I have a heatseal h425 and it is making a loud sound when turned on. The rollers are not rolling and it feels very hot on the outside of the unit.
hi can you please open the laminator up and tell me if there is a rubber toothed belt on the cogs by the motor then i may be able to help.
May 10, 2011 | Gbc HeatSeal H425 Laminator
349 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
