Question about Dell Inspiron B130 Notebook
Starting my laptop
Everytime I start my laptop it always goes through a very long system check. It's about 5 stages. it talks about an NTSF system chek.
A good registry scanner can clean up a lot of problems with your computer. Here's a link to a good free one:
www.your-free-info.com/RegCure
I've used this one and it sped up my computer by quite a bit. Hopefully this helps.
Posted on Apr 29, 2008
    Problem Solver:
  • 12 Answers
More then likely you can go into your bios setting and change start up options. You will have to check your owners manual to determine what key you will need to press to get into your bios. If the laptop is still under warranty I would contact them and they can walk you though the process.
Thanks
Todd
www.LaptopGuy.com
Posted on Apr 23, 2008
How can I fix 8002F334 error in my ps3
I've seen this error code going around for the older PS3's. From what I can gather, it's a HDD issue that can't be cured easily. Here are the steps to take that I found, that seem to work for all PS3 systems.
  • take out the hard drive
  • connect hard drive to pc (running windows 7 64bit, but any windows os should work without other software)
  • open up disk management - in win7 it asked me to make a master boot record, so I did.
  • format in NTSF - that's right, NTSF - don't use quick format
  • shut down pc, take out hd, take usb drive too
  • put hd back in ps3, put usb stick in ps3
  • boot ps3
  • a screen will pop-up saying the hard disk have to be formatted
  • hold start + Select for 5 sec.
  • After formatting the system will restart and the update will start installing
  • configure your ps3 setup - done
  • Remember to get the latest firmware from SONY onto the USB drive.
Jan 12, 2016 | Video Game Consoles & Games
I keep getting error code 8002f147 on my ps3 when it tries to update
take out the hard driveconnect hard drive to pc (running windows 7 64bit, but any windows os should work without other software)open up disk management - in win7 it asked me to make a master boot record, so I did.format in NTSF - that's right, NTSF - don't use quick formatshut down pc, take out hd, take usb drive tooput hd back in ps3, put usb stick in ps3boot ps3a screen will pop-up saying the hard disk have to be formattedhold start + Select for 5 sec.After formatting the system will restart and the update will start installing configure your ps3 setup - done
Feb 23, 2014 | Sony Playstation 3 (PS3) Console
Everytime i turn on my laptop, i hear a weird noise from the ventilator.. it talkes time before it goes silent.. i dont know what is going on and what does it needs to be done.
It's your hard drive spinning up. It's starting to show signs of wearing out. You might consider replacing it before it goes down permanently. Depending on brand they're pretty simple/inexpensive to replace and or upgrade.
Jan 05, 2011 | Computers & Internet
TURNS ON , GOES TO START NORMAL OR SAFE MODE, GOES THRU THE WINDOWS XP SCREEN AND THEN GOES BLANK
Follow the steps below,
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Safe Mode".
Step 5: Select that and HIT ENTER.
Step 6: If you able to login then try accessing System Restore.
Step 7: Click on Start and then click on All Programs.
Step 8: Choose Accessories and then System Tools and System Restore.
Step 9: Run the wizard by choosing "Restore My computer to an Earlier stage"
Step 10: Choose a date displayed in Bold in the calender.
Step 11: Your computer would reboot and wait until the restoration completes.
Hope this helps.
Dec 27, 2010 | Acer Aspire One PC Notebook
Cylinder head torque settings for 1989 Volkswagen Golf?
hi to tighten you have to do it in 4 stages as follows
1st stage 40nm leave 5 mins 2nd stage 60nm leave 5 mins 3rd stage 90 degrees leave 10 mins 4th stage 90 degrees then you are done i will try put order on here i hope this works as follows
10 4 2 6 8 front of engine back of engine 7 5 1 3 9
starting with 1 so it goes like this
10 4 2 6 8
7 5 1 3 9
hope thats some help to you
Aug 09, 2010 | 1989 Volkswagen Golf
Hp 6735b won't start. It just turns off when I try to start it.
There are only few things which we can do if the Laptop doesnt start of shuts down at initial stage. We need to clearly understand the various stages which the system goes through while booting. And based on the stage at which the system shuts down we can analyse if there is an issue with HW or OS. If the system turns off as soon as you switches it on, This could be due to failure in post.. You may have to flash the bios and give a check to the hardware.
If it just starts the cmos and then turns off, think about any hardware which you might have attached to the laptop, remove them and then try, still if it turns off then it could be due to a major hardware detection error, which could also be due to a chipset malfunctioning on the motherboard.
If it runs till loding the OS and then turns off, we have to check the OS Boot files which could be corrupt or lost. I would advice you to take your laptop for a Hardware Check.
Good Luck.
Mar 13, 2010 | HEWLETT-PACKARD HEWLETT PACKARD PCDO...
Desktop will not start.. will only go through Chkdsk
Try and tap F8 and see if you can boot to safe mode and go to my computer and rt click on C, and pick properties then tools, then
check for errors, and check auto,and scan.
Go to dell.com if you don't know who made the hard drive in your model. Then go to the mfg of the hard drive and download a hard drive diagnostic disk to check your hard drive for bad sectors.
You should go to dell.com and check your warranty and you can also ask dell what you should do.
This link posted below has a lot of drive mfg diagnostic tools.
http://www.tacktech.com/display.cfm?ttid=287
Apr 14, 2009 | Dell Dimension 9200 PC Desktop
Toshiba laptop
try updating the drivers to you monitor/screen, and then try updating the drivers to your video card, and then try updating the drivers to your display adaptors, all this can be done by going to start>control panel> system> hardware>device manager>*appropriate category*
Jun 27, 2008 | Toshiba Satellite A60 Notebook
Protect
The protect message indicates that a problem has been detected in the final output stage of the amplifier. The most common failure parts are the output transistors. Plan on a parts cost between $15-$40. Add in the local labor rate for the total repair cost.
Dan
May 28, 2008 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Dell Inspiron B130 Notebook Logo
20 people viewed this question
Alun Cox
