Question about Cameras
When I turn on camera it always shows on the display that I have to check out time and date. I believe that the problem is with inner battery but i cant open camera to look inside.
  • 387 Answers
You are right for that, carefully find out how to open it, be carefull while opening, be inthusiastic, you cant do anything if you afraid of,,
Posted on Jul 27, 2010
Can't get date/time to not appear on screen or download to comp
Are you sure your canon battery pack is OK?If not ,replace it with a high quality replacement battery pack.
Jul 25, 2010 | Canon PowerShot SD1100 IS Digital Camera
Date/time screen always shows up upon startup. Does not remember date/time entered.
Your camera needs a small CMOS battery replacement which saves date, time and maintains these settings even when your camera is off. Look on to the sides of the camera, there will be a small rubber flap which has this battery. You need to replace this small coin-like battery. This battery is not the same as you always use/charge. If you can't locate the small battery, you will find more information in the camera Manual in troubleshooting or camera diagram.
Jan 12, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Sony DSC T10 shows error E: 91: 01. Also flash
1. Turn OFF camera
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Your problem should be solved
Oct 31, 2009 | Sony Cameras
Time/Date stamp doesn't show up...
this camcorder has a built in rechargeable battery for the memory of the date and time, if you do not use it for more than three months, it will discharge all the way; to recharge, you need to plug camera with ac power for 24 hours and the camera turned off. this should charge the internal battery complete.
Oct 08, 2009 | Sony Handycam DCR-TRV250E Digital...
The date will not stay set. Every time we turn the camera on it opens with the date screen. We set the date and it then goes into shoot mode but the date is not set. All pictures are stamped with the...
to keep the date on, you have to leave the camera off with a charged battery for 24 hous to charge the inner battery that keeps date on. If this doesn´t solve the problem then is because the inner battery won´t charge anymore, but it will take pictures as normal without the date. To avoid this don´t leave the camera too long without use or with a worn battery.
Oct 04, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Camera reverts always to 2006 date when power turned off
Hi There. 1st go to menu Then Go To Memory Then select Flash. This will hold the date when taking the battery out. Av A Good Weekend Regards Alex
May 21, 2009 | Pentax K100D Digital Camera
HOW TO DISPLAY DATE AND TIME
I checked the manuals and I believe that the function you want is not available within the camera menus.  The date, time, and lots of other information is included within each file that holds individual pictures.  The software you use to view and edit pictures should show the information to you and may allow you to manually add the date to the picture.  I use Photoshop Elements 6 (Mac) and it will allow me to put the date and time on a picture.  You might consider adding the date and time to the name of the picture file if you want a quick reference to the date and time
Jul 11, 2008 | Canon PowerShot S3 IS Digital Camera
Cameras Logo
19 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
