Question about Dryers
I have a gas dryer that I need to hook up. Previously there was an electric dryer there. So I need to know what to do to be able to hook up my new gas dryer.
    Genius:
  • 1,073 Answers
Unit will work on 120 volts instead of 240, vent will work from old dryer 4 inch in size the gas hook up is where you need the gas company to come and run the gas lines and regulator and the tank for the gas
Posted on Apr 23, 2008
I have a imperial whirlpool dryer. I thought it was electric, it has gas hook up and a electric plug as well , can it be bothZ?
Yes, it will be both. A straight electrical dryer is hooked up to 220 volts of electricity and uses that voltage to run both the motor and the heater. In a gas dryer, you only need 120 volts to run the motor and run the igniter for the gas, which provides the heat to dry your clothes. Hope this helps!
Feb 24, 2015 | Whirlpool Dryers
Our old maytag dryer was hooked up to gas and electricity. we got a new dryer plugged it in and it works but does not heat up. does it need to be hooked up to the gas also?
A gas dryer will have a model number in which the second letter is G as in MGDC
An electric dryer will be ME...
Does that help?
Gary
Sep 04, 2011 | Dryers
Clothes not drying completely; takes about 5 cycles to get them dry. Was previously drying completely with one cycle. I believe I need a new heating element and would like assistance on getting...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 20, 2011 | Whirlpool Dryers
Moved to new house and it's not a gas hook up just electric
You will have to replace the dryer with a electric one or have your local gas company install tank and run lines for you unless there's natural gas line where you live which you will need the city come and run a line or a qualified gas technician come do it but this will be costly. I would recommend buying a good quality used one or a new one it would be cheaper. Also since the gas prices have been sky high on propane and NG allot of people have switched to electric over the last two years and most appliance company's even mine wont trade or give anything for it just a fyi but good luck and hope this helps.
Jan 10, 2011 | Hotpoint NVL333GY Gas Dryer
Can you convert gas to electric dryer
I need to convert my electric Maytag dryer to Gas
The sales person at Home Depot said we could that's why we got this one
anyone know anything about this?Help
Nov 14, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Old GE drier - Is it gas dryer or electric
it's a gas and you need a new gas or a 220 volt dryer.
Jun 24, 2009 | GE DCSR483EA Electric Dryer
Just hooked up outlet. Dryer tumbles, wont heat. Have I wired the outlet wrong?
Hi, Did you put red and black wire to the outer posts? White wire ti center and green to ground screw on cabinet? Dry will run on 120V but needs 240V for heat. Make sure there is 240V to the outlet as well.
Hope this helps. If so, please feel free to rate my answer so that I know how I am doing.
Vic
May 10, 2009 | Dryers
Gas Dryer DLG5966W pilot light
The power should turn on a electric igniter once the gas has reached the heat chamber and regulator. If not let me know soon the model number of your LG dryer so I can help you better, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Apr 09, 2009 | LG Dryers
Convert a gas dyrer into a electric dryer?
Sell the dryer and get an electric one. Conversion is not possible. Be advised that electric dryers run on 220 volts and require a special plug. hope this helps!
Jan 07, 2009 | Kenmore 73952 Gas Dryer
Can dryer be converted
ummm, hter is NO way to convert a gas dryer to electric, you can have a gas dryer converted from naturall gas to lp gas, but not to electric, two totally different machines.
Nov 23, 2008 | GE Profile DPSB620GCWW Gas Dryer
Dryers Logo
Top Dryers Experts
