Question about SpeakerCraft Amplified Terminator Unit
How to hook up? Hooked it up and does not work. Speakercraft AT- 1.0 amplifier
2 Suggested Answers
SOURCE: Speakercraft DBB12100 Amplifier, Circuit problem
Sounds like its a problem with over heating. open unit clean out all dust and dust bunnies wich compressed air. check that all fans are opperating. (fans on 6x100 amp units or thermal controled). If amp goes into protection prior to fans turning, there is your answer. the @ power supplies will have a green light on the output side. if the light in on power supply is good. or you can check that the output voltage is at 48Vdc on both units.
Posted on Sep 18, 2009
How do I hook up a microphone to a Speakercraft MZC-66?
This unit accepts LINE LEVEL audio signals only. You cannot attach a low level microphone directly to this unit. First, it doesn't have the correct inputs for a direct connection. However, you can use a microphone pre-amp that will accept the appropriate jack for the mic and it will provide a line level output for the Speakercraft. You would have to choose one of the inputs on the MZC such as CD, or source.
Sep 29, 2014 | Audio Players & Recorders
It was hooked up to a 2 or 1 ohm load now it dont work
if it was hooked to a 1 ohm load its most likely fried. what watt were you trying to push?
May 29, 2011 | Rockford Fosgate 25 To LIFE Punch 150...
We have a SpeakerCraft MZC - 66 amp. This powered and operated ok on Friday and has just stopped working. There does not seem to be any power going to the unit. Any ideas?
is this generstion 1 or 2 on the mzc.. gen 2 has a fan built in on the top, if it is gen 1 Im sad to say every one I encountered with this problem needed to go back to speakercraft. the will sell a refurbished one at a discount
Apr 04, 2011 | SpeakerCraft MZC-66 Amplifier
Hi can anyone help, i have a speakercraft mzc64 and need to use some premade cat5 patch leads to hook it up, i know the wiring is not standard,,,asny ideas please
What are you using the CAT5 for - speakers or Line Level?
Lamp cord would work (cheap) for the speakers and there's no reworking necessary. I wouldn't pass Line Level on CAT5, ever.
Feb 13, 2011 | SpeakerCraft MZC-64 Amplifier
Got this amp 3 years ago but never opened the box before today. I hooked it up but now it wont turn on and the fuse is fine. ?? Thanks,
If you know how to use a Volt meter, measure the DC outputs of the power supply. The power supply section might have a cold soldered connection that opened due to none use.
Jan 21, 2011 | SpeakerCraft BB835 8-Channel Amplifier
I have the same SpeakerCraft mzc-66 Model. Installed 2005. About 2yr later on one of the zone that was rarely used, it started to just put out a clicking noise. It is now down to only zone 1 and 6 that are...
I repair these:
http://calgary.kijiji.ca/c-buy-and-sell-electronics-Speaker-Craft-MZC-and-BB-Series-Amplifiers-Repair-Service-W0QQAdIdZ229607818
So they never fail again...
Jan 17, 2011 | SpeakerCraft MZC-66 Amplifier
Sep 18, 2009 | SpeakerCraft DBB12100 12-Channel Amplifier
Need to find a repair center for a Speakercraft MZC66
just find a good amp repairman he can fix it for you.google one.
Sep 01, 2009 | SpeakerCraft MZC-66 Amplifier
Thunder 5604
okay u will have to troubleshoo the amp.....dose the amp light up?...when u have the radio on? also check your sub wires.going to the amp....make sure the rca'sare hooked up to the radio rear out puts are the radio sub out puts...and then test your amp gain adjustment...let me know if that work's
Jun 23, 2008 | MTX Thunder5601 300W x 1 Car Amp Mono...
SpeakerCraft Amplified Terminator Unit Logo
65 people viewed this question
Top SpeakerCraft Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
Ronny Bennett Sr.
Ronny Bennett Sr.
Craig Butler
Craig Butler
Are you a SpeakerCraft Audio Player and Recorder Expert? Answer questions, earn points and help others
