Question about Whirlpool WTW5300SQ Top Load Washer
Whirlpool wtw5300sq0 doesnt reach desired water level, shuts off water flow at low level only. How to tell if it is switch or level sensor?
  • Anonymous Mar 25, 2014
    water level is too low
    President:
  • 2,468 Answers
Your level switch sensor needs to be replaced on the control panel
Posted on Jul 27, 2010
What does Code nf on washer machine Samsung vrt model mean
NF indicates no water flow. This could mean that the incoming water valves were shut-off, the incoming water flow is low, or that the washer didn't detect the water flow into the washer correctly. If the drain hose is too low, the washer could fill and drain simultaneously. This can also cause the problem.
First if the washer is not getting any water, then check your shut-off valves and the hoses. Disconnect the hoses from the washer and place a bucket under them. Check the flow by turning on each valve for a bit. Clean or replace the filters at the shut-off valves and in the washer. Consider replacing the hoses. Some anti-flood hoses will reduce the water flow if they detect leaks. Make sure that the hoses are not kinked. If the water flow is good at the shut-off valves, then the inlet valve may have failed in the closed position.
If water is filling the washer, then the problem is in the water flow detection system. This could indicate the small reed switch is damaged, the air tube to the reed switch is clogged or that tube has a hole in it. Some washers check for fill by the change in the drum weight. This signal may not be reaching the control unit due to a problem with the sensor or the wiring.
If the washer is filling and draining, pull your drain hose up. It is below the washer fill level. This creates a vacuum that will drain the washer.
I hope this helps.
Aug 25, 2017 | Samsung Washing Machines
Why 4E error code keep appearing on my Samsung washing machine
The 4E error indicates that the washer hasn't detected enough water coming into the unit. The problem could be in your incoming water line (low water pressure), the washer hoses, the inlet valves, or the sensors that detect the length of time to reach a specific amount of water in the washer. It can even be caused by having the outlet hose positioned too low in the discharge pipe or sink.
First check the obvious possibilities: make sure that the shut-off valves have been opened. If you hear water running into the washer and then into the discharge plumbing after a few minutes, raise the end of the discharge hose to a level above the washer fill level.
Shut-off the incoming water and remove the washer fill hoses. Place a bucket under the hoses and open the shut-off valves. Check that you have good water pressure; the washer is looking for the tub to fill in about 8 minutes. Then turn off the water. Clean the filters in the hose at the shut-off valves and the ones inside the washer at the inlet valve. You may want to replace the washer fill hoses; some anti-flood hoses will constrict if they detect a leak and limit the water pressure.
If the water flow at the hoses is good and isn't exiting the washer, then the problem is either the inlet valve or the water flow sensor. Does any water reach the tub? If it doesn't, check the inlet valve and make sure that it is getting the proper electrical signal from the control unit. If water is reaching the tub, then the problem in the flow sensing system. Some washers use an air tube that helps check the pressure in the system. If this tube is leaking or clogged, the sensor will give incorrect messages. Other systems have a small switch that moves as the water passes through the inlet valve. This can fail.
There can be other problems that give the same symptoms. If you post the model number of your washer, I may be able to point you to the correct diagnostic steps.
Nov 04, 2015 | Samsung Washing Machines
Whirlpool washer AWG 305, water doesn't stop.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Jan 24, 2013 | Whirlpool Washing Machines
My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Sep 13, 2011 | Washing Machines
Hi hoover 600 mb water wont shut off when it gets to the right level even when i push in the button and un plug it can you help Thanks
This is a failure of the inlet valve if the water flows all the time but if the water flows uncontrolled only when the machine is put on start then it is the failure of the WATER LEVEL SENSOR which is normally a pressure switch.
When the level of water reaches the set level then the pressure of the water will switch on the switch to contact and so give message to the controller to SHUT down the inlet valve.
Jul 07, 2011 | Washing Machines
The water is not shutting off and moving to the next cycle.
Possible that the water level controller switch is defective. this is normally a pressure sensor and *** the water flows up the diaphragm within contracts to switch the contact and so trigger the circuit to stop the flow and move to the next cycle.
please check this out.
Mar 28, 2011 | Whirlpool Washing Machines
Kenmore 110-20932-994 overfills with water (keeps fillilng)
Water fill sensors are electronic and may become insulated with detergent, grease, scum, and the like. All it may need is a good cleaning if its electronic. Consult with the manufacturer as to what and how. These sensors are usually imbeded in a plastic polymer of some kind so you wont want to use anything like nail polish remover... Also if electronic the sensor may be fine and the board or a section of the board is out.
If its electro - mechanical type switch :
Water fill switches usually have an air tube that as the water level comes up the air pressure increases and causes the switch to go from fill to wash.
I have seen rodents chew holes in the air tubing and this could be the cause or you may have a bad switch.
Some times the switches also get out of calibration and need readjusting (especially if you have moved in altitude like up a mountain or into a valley).
If this helps you please rate me as high as possible.
If it doesnt help you please rediscribe your problem in more detail to help me understand, post back and I will follow up.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Water does not stop filling. Causes it to over flow. Large amounts of water flows from under the machine. Can you tell me if there could be a problem with a sensor or something?
It's overfilling If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Mar 11, 2009 | GE Washing Machines
Washer filling up improperly
Well its definately not your water level switch, so that only leaves your water fill valve at the back of the washer, the cold valve is stuck open by debris. hope this helps
May 18, 2007 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool WTW5300SQ Top Load Washer Logo
211 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
