Question about HP DeskJet 5550 InkJet Printer
PUT NEW INK CARTRIGES AND THE LIGHT STILL BLINKS THAT TELL ME WHEN IT NEEDS NEW INK, HAVE TURNED OFF PRINTER AND EXCHANGED NEW CARTRIGES AND STILL THE LIGHT BLINKS. WHAT IS THE PROBLEM
    Problem Solver:
  • 7 Answers
You didn't say whether these new cartridges were HP original or knockoffs or remanufactured units. If they are HP original then that suggests a bigger problem. If they are the other types then try taking one out at a time with printer on. Then shut it off with only the one in its cradle. Then turn it back on...if the light goes out then the one you removed is most likely defective. If the light is still blinking then switch the cartridges and see if that turns out the light doing the procedure above. You should have either the 56 or the 57 not both in their respective cradles. If the light doesn't go out then you might try cleaning the electrical contacts in the printer with a cue tip and 91% alcohol or distilled water....just make sure the contacts get dry before retrying any of the above. If these are NEW (in warranty) HP cartridges then you can send back but try them one at a time to see if just one of them is defective. HP also has email support on their website and you might try calling their tech support but don't expect a lot of help...this is an old printer.
hope this helps.
Posted on Aug 18, 2010
Dell 720 printer , new ink cartriges but prints blank pages
I know it sounds silly, but never underestimate the obvious.
Did you remove the plastic protectors from the cartridges?
Another solution maybe to return the cartridges to the store for an exchange. It has only happened once to me, but I exchanged the cartridge for another "new" one and it worked fine.
Good luck
-Carlos:
Jan 07, 2010 | Dell Inkjet 720 Printer
Check print cartridge light blinks
pull the cartridges, with the power turned off swab w/ alchol swab the communication ports that the cartridges fit into, let dry then reinsert the cartridges and turn on the printer. The com ports get infiltrated with ink wont read the new cartridges.
Oct 12, 2009 | HP PSC 1315 All-In-One InkJet Printer
My kodak 5300 printer said i need ink i put in new ink but it sai
check the cartriges head and reinstall your printer and for information contact http://tinyurl.com/m7ghqz
Jun 18, 2009 | Office Equipment & Supplies
Canon i960 qill not put ink on paper
I called Canon. I also had green 1 flash and amber 1flash everytime I turned on the printer. That right there indicates an elecrical problem. The flashes mean it needs serviced and with it not printing now means it's not wirth fixing, out of warranty. Canon did offer a code for reduced price new or referbished print from them.
May 27, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Ink cartriges not being recognized by printer
It is not uncommon for an Epson printer to fail to recognise Epson cartridges. It is either due to failing to go through the proper cartridge replacement cycle properly, or more seriously, due to a communication problem between the cartridge and the main board. To fix the first, simply go through the cartridge replacement cycle again (see your manual how to do this before the cartridges are empty). Simply take your new cartridges out when told to, and put them back in again when told to insert the "new" cartridges. If it's the second problem you need specialist help, or simply sell your printer on e-bay for what you can get.
Dec 17, 2008 | Epson Stylus Photo 830 InkJet Printer
Printer indicating out of ink
Hi! joeandtam
Did you run a cleaning cycle on your cartriges? Check your tool options from your Programs/HP page.
InMrFixIt
Nov 08, 2008 | HP DeskJet 810c InkJet Printer
Message on screen
Try updating your print drivers:
Create a new folder on your desktop and name it newhpdrivers. Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Oct 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
Printer won't print
HP Printer won't Print Pictures after I Put New HP Cartriges of ink in it?
Jan 07, 2008 | HP PSC 1350 All-In-One Thermal Printer
Brand new Printer lights flashing
You should install driver first, then connect printer when prompted, then install inks, as it needs the driver to tell it there are full inks fitted, refer to the manual.
Dec 20, 2006 | Ricoh Aficio G7500 Printer
HP DeskJet 5550 InkJet Printer Logo
48 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
