Yamaha RXV-485 control is set up, our daughter unplugged the wii while the unit was on and now we can get no sound from the main speakers help help help
4 Suggested Answers
SOURCE: Yamaha rxv 595 receiver shuts down when volume is increased
THE SPEAKER WIRES ARE REVERSED.... On the receiver the red side is always positive and black is always negative.
change + to - or
change - to + on one or more speakers.
positive side--------------------negative side
red --------------------------------black wire
gold wirew/silver--------------silver wirew/gold
white lined----------------------non-white lined
Posted on Oct 30, 2008
dunnbiker
  • 8546 Answers
SOURCE: my yamaha rxv 650 volume
yes it is
Posted on Apr 06, 2011
Testimonial: "thanks very much"
joeguest2
  • 2080 Answers
SOURCE: Can I hook up a
First of all, here is the main ONLINE SUPPORT page for your model:
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v493_black__u/?mode=model
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V393.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
You should just be able to use the TAPE REC AUDIO OUT (L/R) jacks on the back of the Yamaha 493 unit as your secondary amp's input signal. You might even be able to use the VCR AUDIO OUT (L/R) jacks as well. See page 8 of the manual for a detailed diagram of the rear connections on your set.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Posted on May 25, 2011
Yamaha home theatre system RXV 350 amplifier
Check it without speaker connection. If the set does not go to protection mode, check all the speakers by connecting one by one at a time and switch the set ON; to find the faulty speaker. If the set goes to protection mode even no speaker connected, check and replace damaged components at its audio output section circuit. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 07, 2014 | Yamaha RXV-350 Receiver
Unit goes into protection after a few seconds. Yamaha amp model no RXV 350
Disconnect all the speaker connections, and just switch the set ON. Even now the set goes to protection mode, the fault will be with its audio output section circuit. If it does not go to protection mode without speaker connections, check all the speakers. Connect on by one at a time; and switch ON the set; thus you can get the faulty speaker box. http://electronicshelponline.blogspot.com/
Oct 07, 2014 | Audio Players & Recorders
Yamaha RXV 1400 RDS and subwoofer stopped working
If it is new, just send it back for warranty repair.
Jan 13, 2014 | Audio Players & Recorders
Speakers not playing
The problem can be the cable or speakers or RX-V463 or settings. Need to check one by one.
Set the RX-V on DTS or Dolby Digital
1) Check Cables - connect the 2 (surround) cables from RXV's Centre Out to Centre speaker. If the Centre speaker works, then cables are ok.
2) Check speakers - Connect each Surround speaker to RXV's Centre out. If it works Speakers are ok.
3) Check RXV - Set it on DTS or Dolby Digital
Connect RXV's surround out (one at a time) L and R to the Centre speaker. If there is no sound, the problem could be RXV's settings (I need to read the manual).
Hope this helps.
Nov 20, 2013 | Yamaha RX-V463 Receiver
YAMAHA RXV 350 Right Speaker not Working
The amplifier for this channel is NOT working.
Feb 09, 2012 | Yamaha RXV-350 Receiver
YAMAHA RXV350 RIGHT CHANNEL NOT WORKING
Adding on again: I have interchanged speakers, if i connect any speaker on the right front channel it will not work. When I do a automated speaker test only right front channel does work.
Jan 26, 2012 | Yamaha RXV-350 Receiver
Hi, I have a Yamaha RXV 459. Have speakers of DSE. The speakers are of 8 impedance. Was listening to music till 4 hrs ago. Switched off the whole unit from the power source. Returned and the unit is...
Disconnect the speaker one at a time, you may have a shorted voice coil, the message was indicated a short in the speaker wiring. If no joy then you may have burned out the power transistors.
May 16, 2017 | Yamaha RX-V459 Receiver
My Yamaha RXV -2500 started switching audio signals from one componet to another! Example - Sat/Cab sound coming out of the Wii and Wii coming out of the Sat/Cab. I have not touched anything and this...
You need to go into the "GUI" menu and re-assign the audio inputs to the correct source. The manual will walk you thru it as well. If you still need further help, post a comment or reply and I can help with further detail. Hope this helps.
May 31, 2011 | Yamaha Rx-v565 Receiver
How do I use the remote to cont bass & treble for rxv-657 reeiver
No, Tone controls are on the front of the unit only. If your passing video thru the unit you can go into the setup menu from the harmony and adjust all the sound parameters that way "on screen" The only "EQ" capabilities are for the Center channel only. You can adjust "speaker size". "Large" setting will give you a little lower response. "Small" will crossover the speaker at "100hz" That's about as far as tone adjustment goes on this unit. Hope this helps
Jun 30, 2009 | Yamaha RX-V657 Receiver
Yamaha reciever rx-v363
Thats because if you look in the owner's manual, it declares the fact that it will only broadcast sound from hdmi to monitor not speakers. For sound out of speakers need to connect additional audio cable.
Apr 21, 2008 | Yamaha RXV-350 Receiver
105 people viewed this question
 Grubhead
Grubhead
