Question about Linksys Wireless-G WRT54G Router
When i plug in my Linksys wrt54gs my computer says that i have limited or no connectivity to the net?
    Problem Solver:
  • 15 Answers
Hi, before anything check if you have "set ip address automatically" on the network card properties. As a second step you could reset the router to it's factory settings pushing the "reset" button on the back of the router for about 5 seconds. I hope it works.
Posted on Jul 27, 2010
Is there a limit to how many computers can connect wirelessly to a linksys WRT54GS router? I can only hook up a couple at a time. To change access between laptops, I have to disconnect all from the router...
Get into the routers management/setup and look to see if there is an option to alow more then two to connect. I have a wireless router that I have 4 laptops connected to. Good Luck hope this helps.
Jul 06, 2010 | Linksys Wireless-G WRT54GS Router...
Not getting in to the enter net.
Make sure your cable/DSL cable from your wall outlet is plugged into the "Internet" port on your router, and a cable from one of the 4-ports is plugged into the network card on your PC. Then, open your browser and type in the IP address of the router (default is 192.168.1.1). The Linksys menu should appear, and you can begin to configure it from there.
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Feb 22, 2010 | Linksys Wireless-G WRT54GS Router...
My Linksys WRT54GS ver. 6 Router continuously blinks
Try un-plugging all the cables from the router for 30 seconds, then re-connect them.
Hope this helps!
Feb 04, 2010 | Linksys : WRT54GS Wireless-G Router W/...
The port of Linksys Wireless-G WRT54GS Router Linksys Wireless-G WRT54GS Router
What do you want to know about the ports? The one separated from the other ports is the Internet port. that is where you're going to connect the cable from your modem. The other four are the ethernet port where you will connect the computers.
Jan 22, 2009 | Linksys Wireless-G WRT54GS Router...
Wrong ip address, need to reconfigure
Im assuming youre using an integrated ethernet card since you say "adapter port" and "unplugged". So....
Since you reformatted your HD with O/S re-installation you may also have to reinstall or update it to the correct ethernet adapter driver. As far as the ethernet card set-up - copy your ethernet card property configurations from the other computers. Also copy configuration settings from your Internet Explorer options.
Jan 11, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys WRT54gs
ya if firewall is there then remove it when you connected your net after then you give the friewall.
for the security settings you have to go for the router page and go there one option is there security enable go for it
May 21, 2008 | Linksys Wireless-G WRT54GS Router...
Computer says router not supported.
I think your configuration have a problem try to reset the reset button of the router. Press the reset by using a tip of pen by 15 second and try to connect. If still not connected try to run again the setup configuration of the router.
Apr 24, 2008 | Linksys Wireless-G WRT54GS Router...
You just needed to Connect ur router to the computer
1>open Internet explorer type 192.168.1.1 and then Enter
2>Leave the username blank and password admin(lowercase)
3>then in linksys page change the Local IP of the router to 192.168.2.1 and then power cycle the network it will not create any problem later
Mar 08, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys WRT54GS
Have you tried different ports. If the firmware is not eliminating th e problem, then I suspect its the router itself. Try firmware one more time as per linksys suggested, if that does not solve then I suspect you need to buy a new router.
Hope that helped!
Dec 15, 2007 | Linksys Wireless-G WRT54GS Router...
Linksys wrt54gs cant connect..
hi try this before you hit the reset botton. Check if Windows XP firewall or 3rd party firewall are blocking the pings, and temporarily disable them just to be sure. The WRT54GS has a feature called "AP Isolation", It's on the "Wireless -> Advanced Settings" page. You won't need it for home use so turn it off as well. Last thing, do a firmware upgrade. Hope it's helps Good luck.
Mar 20, 2006 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G WRT54G Router Logo
115 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
