I have WG11v3, adapter and have all lights ready except. It tells me about the ip address is needed. How can I put that in. I provider is verizon and they tell me I will have to get that answer from the netgear wireless. What can you tell me or help me?
  • 396 Answers
Click on Start and then Control Panel. Select Network Connections. Right click on the local network adaptor you are setting the IP address for. Select properties. If you do not see Internet Protocol (TCP/IP) click the install select protocol and add then Internet Protocol TCP/IP and ok. Click on Internet Protocol (TCP/IP) and properties. If you do not know the IP Address select obtain IP address automatically and OK. Click OK to close and save Local Area Network Properties. See if this works otherwise you will need to find the IP Address for your modem.
Posted on Jul 27, 2010
Ip location
no. An IP address refers to an address that is attached to your network card (or your router). In most cases you will have what is considered a "Private" address (there is a range of addresses reserved for people to use in their private networks so that they don't get confused for things on the internet). So your computer will have a "private" address if you are behind a firewall, router, or internet service provider. You may be looking for your "public" address which would not allow someone to get to your computer from the internet, unless you had "port forwarding" set up in your router. Public addresses usually do not stick to your cable modem or dsl modem, and may change over time. If you need to figure out what your current Public IP address is you will want to go to google and type "what's my ip address" in the search, and it will show you (as well as some links to other web sites that will tell you what your IP address is). If you need to find your private IP address so that other computers on your private network can communicate with you, open the command prompt and type "ipconfg /all" and hit enter. This will give you a list of different adapters that you have on your computer, and what the IP Address is for each (you may have wireless, hard wired, even vpn adapters). The email address that is transmitted in the headers of your email is the public IP address of your mail server (or googles, or yahoos, or whatever your mail provider is).
Hope this helps.
Feb 04, 2014 | Computers & Internet
Ip address dynamic
Dynamic and Static addressing are the two main methods used for IP address assignments. Dynamic IP addresses are automatically obtained and nothing needs to be done on the user end. However, Static IP address information must be configured manually. If you do not have a router, you need to input your static IP information directly into your Apple Macintosh.
Click "Apple > System Preferences." Click the "Network" icon. Click the "TCP/IP" tab. Choose "Manually" in the Configure drop-down menu. Click in "Show" and choose your Ethernet device. This is usually called Built-in Ethernet. Enter your IP address into the IP Address field. Enter the Subnet Mask into the Subnet Mask field. If your service provider did not provide you with one, use the default of "255.255.255.0". Enter the Gateway address into the Router field. Enter the DNS Server into the DNS Servers field. Two should have been provided to you. Push the "Apply Now" button to confirm changes.
Apr 07, 2013 | Belkin Ethernet Adapter F5D5050 Network...
Can you tell me the default IP address for this unit as I have lost the pass word and need to reset the unit
If your computer is plugged into the router, you can easily get the router's IP address by going to your command prompt and typing "ipconfig" without the quotes.
Command Prompt is under Start (or Orb if using Win7 or Vista) > All Programs > Accessories
After typing "Ipconfig" and hitting return, command prompt should display something like this:
Windows IP Configuration
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . : blah.blah.comcast.net.
IP Address. . . . . . . . . . . . : 192.168.0.196
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Ethernet adapter PdaNet Broadband Connection:
The router's address is your "Default Gateway." You should be able to put that address into an Internet Explorer window and it will bring up the configuration interface.
If you find this helpful, please rate me -- trying to get my "Wiz" rating so that I can provide Premium service.
Thanks,
Chris
Jul 27, 2011 | 2wire 2700HG-B Router (2700HGB)
Cannot access webbased user interface using IP address for Belkin router. Instead it goes to webased user interface for verizon modem. This occurred just yesterday when I accidently changed the modem to...
>They're just trying to escape from their responsibility
>you know why?
>if that's what's happening, it means that the modem is NO longer on Bridged Mode
>router's won't worked if the modem is not bridged
>since it is a verizon provided modem they should be able to help you out.
Here's the right script to tell them:
>"i'm calling in to ask help in setting my Verizon Provided modem to Bridged Mode."
>it is also advisable to Unplug the belkin router first. i'm sorry this tip is not that helpful but working with an ISP before I know what are scope of support is ?
>comments ratings suggestions and violent reaction will greatly be appreciated
Sep 19, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to get the ip adress from a linksys rtp300 phone adapter
I'm not sure if your asking for the IP ADDRESS of your Linksys or the DEFAULT GATEWAY of that device because your router's ip address will be provided by your server or Internet Service Provider (ISP) depending on your service. There are two ways of obtaining an ip address first will be DYNAMIC, where your ip address changes all the time and STATIC where you are given specific ip addresses for example 192.168.0.1 -to 192.168.0.25. The easiest way to obtain those ip addresses, by the way, is to contact your Internet Service Provider (ISP)
example: AT&T, Roadrunner, Time Warner, etc....
But, if your looking for the DEFAULT GATEWAY for you to access your router's configuration, most of the time it is found underneath the router itself. For Linksys the Default Gateway is 192.168.1.1
>I hope i helped you out with this... Enjoy!
Sep 15, 2010 | Linksys VOIP PHONE ADAPTER 2-PORT (PAP2NA)...
Can not connect to Verizon MiFi2200 wireless network
Yes the verizon tech informed you right that the ip address will be acquired by your wireless adapter automatically. However there are lots of reason that your adapter not able to connect wireless.
1. Make sure no firewall or antivirus is blocking your wireless connection to connect wirelessly.
2. Make sure you are entering the right password for the wireless network if your network is secured.
3. Make sure the wireless adapter driver installed properly.
4. You can also try to restart the DHCP services through which your computer will try to get the ip address. I am giving you the steps how to restart the DHCP service once again.
- Click on start
- Under start search or under run type in services.msc
- Search for DHCP client and right click on that and you can click on restart. It will restart your services.
5. Make sure other computer are able to connect wirelessly to identify whether there is a problem with the router or a wireless adapter.
6. Make sure the wireless channel on the router is correct sometime due to wireless channel your computer not connect.
I hope this will help to resolve your concern. Still if you face any problem let me know.
Thanks & Regards
Jazz
Jun 27, 2010 | Linksys Ultra RangePlus Dual-Band...
Limited or no connectivity
When your computer does not get IP address from the router, you get the message " limited or no connectivity ". There might be 2 possible reasons for this . 1) If your wireless network is secured then you are not entering the correct network key. Open the set up page of the router and check the wireless settings of the router .
2 ) Your router is giving the IP address to the rotuer.
Open the set up page of the router and check , the DHCP server is enabled or not ? It should be enabled.
You are entering the corerct network key and DHCP server is enabled, but still getting the same message. Assign a static IP address to the computer.
Click here for more instructions
Mar 29, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I am unable to connect to the internet using a wireless connection (signal strength good) When I use the repair wizzard I get a message telling me unable to renew IO address
If the Wi-Fi access point is a DHCP enable router, you should be able to browse the internet as DNS address will be automatically fixed in the Router firmware.
to check what IP address is assigned and more information on your wireless adapter
go to Command prompt by typing "cmd" in RUN.
type "ipconfig /all" without the quote.
you should be able to see IP address of your wireless network adapter plus default gateway and DNS address which are much needed in order to have internet access.
you can still assigned IP address etc manually.
Go to "Control panel"
Click on "Network and Sharing Center"
Click on "Change Adapter setting"
Now, right click on the wireless adapter and select "Properties"
Select "Internet Protocol version 4 (TCP/IPv4)" and "Properties"
In General tabs,select the radio button with " use the following IP address"
IP address : 192.168.1.x    (if the router IP address is 192.168.1.y)
                                        x=1 to 254, y=1 to 254 but x should not be                                           equal to y )
Subnet Mask : 255.255.255.0
Default gateway : 192.168.1.y ( IP address of the Wireless access point)
Preferred DNS address : Ask the Internet service provider
Alternate DNS address : Ask the Internet service provider
Click "OK" twice.
Your Internet should work now.
Jan 26, 2010 | Fujitsu Siemens LifeBook N3520 Notebook
Configuration
The best way to set this access point is to connect your computer directly to the device via Ethernet, disble the wireless adapter temporarily on the computer. Since this is just an access point and not a wireless router, it is not capable of providing your computer with an IP address because it has no DHCP functionality.
The IP address you mentioned is the deafault IP address of the access point, there is a posibility that the default IP has been change.
Do a reset on the access point then assign an IP address manually on your computer(i.e 192.168.1.x x- bein any number from 1 to 254 except 50)
Access the AP using Internet Explorer or Firefox, type http://192.168.1.50 on the address bar it should prompt you for a username and password(check you documentation for the default username and password for the access point)
Aug 09, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
Computers & Internet Logo
101 people viewed this question
Alun Cox
David Payne
David Payne
