Question about Akai PDP4225M 42 in. Plasma Television
TV was not working. Replaced fuse and it came on for a few seconds. Loud pop heard and screen went black
  • egraham379 Jul 27, 2010
    double checking.
  • 10,594 Answers
If it is Akai PDP4225M plasma tv then power supply board seems defective and defective Y-sustainer and Z-sustainer boards can also blow up power supply board.
Below image shows above said three boards location in tv and board replacement/ swapping is only way to rectify problem because these boards are not suppose to be repaired on component level.
Thanks.
Posted on Jul 27, 2010
    President:
  • 1,099 Answers
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Samsung plasma screen went black. Was watching tv, heard a loud pop and the screen will no longer turn on. You can hear the tv turn on but no picture. Power is still working, just a blank screen.
Issue is either with the X or Y sustain board. Look for a cap that has blown or a cracked solid state device on the board. One of them is responsible for the ***** croak you heard.
Jul 28, 2017 | Samsung Televison & Video
How to diagnose my led tv issues
You most likely had a capacitor let go, they make a pop when the go out, inspect the PCB for a burned mark.
Oct 12, 2016 | Toshiba Televison & Video
Pop sound then no picture, just sound
I assume this is a plasma TV? You will have a fuse blown on either the Y or Z sutain board, there is also a possibility one of the driver IC's has blown on the buffer board, this will shut down the screen & leave the audio working normally. You can check these boards which sit on the left & right hand sides of the screen.
Sep 23, 2009 | Televison & Video
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
I heard a loud pop then tv screen went black, now
hi friend,,,,,,,
i think due to high voltage resistor in dma board has blasted,,,,,
did u see any burnt marks,,,,,,,,,reply me
thank u,,,,,,,,
May 03, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Loud pop Blank screen 42 inch Viore Plasma
Unfortunately, that board is the inverter board. And for this model the inverter board is only supplied with the the PDP panel. The panel is quite expensive, here's a link if needed:
LG 42PX5D Replacement Part PDP Plasma Display Panel
Dec 26, 2008 | LG 42PX5D 42 in. Plasma HDTV
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
May 18, 2008 | Samsung HLN5065W 50" Rear Projection...
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Vizio P50 screen refresh
power supply.Definately will need to be replaced. Im actually looking for one to replace myself.TV repairs charge 1200 to repair.
Nov 01, 2007 | Vizio P50HDTV10A 50 in. Plasma HDTV
Toshiba tz50v51 popping sound
Possible problems: * The TV set may be unplugged. * A fuse or circuit breaker may be blown or switched off. * The remote control unit (RCU) may be disabled. Solutions: * Make sure the TV/VCR are plugged in and the wall switch is on. * Check the fuse or circuit breaker. Test the outlet with a lamp. * Replace the RCU's batteries: if this fails exchange the unit.
Jan 18, 2006 | Toshiba TZ50V51 50" Rear Projection...
Akai PDP4225M 42 in. Plasma Television Logo
53 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
