Question about Fender Frontman 212R 100W 2x12 Guitar Combo Amplifier
Everytime I play on my Fender Frontman 212R the amp switches betweeen the overdrive and clean channels. I can't even switch between the channels on my own. It does it itself. I need help fixing this problem.
  • Fender Master
  • 5,603 Answers
You don't say if you are using a footswitch or not... If you are, the switch, cables and connectors are suspect.
If you are NOT using the controller, the switch contacts on the footswitch jack in the 212 are suspect as being intermittent contacts.
If the contact is not making, the OD switch on the unit will NOT work either.
These jacks, and their contacts are JUNK and often cause problems.
Open the unit and increse the tension of the contact springs.
Posted on Jul 27, 2010
Fender Frontman 212R crackling noise
After ruling out guitar wiring or bad cables...
Try the 2nd input on the amp
also
Is it on both channels, or just one?
Nov 01, 2013 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Hello! I was recently playing and found out then whenever I play specific notes on any of my guitars, my Fender Frontman 212R will buzz. The notes that always buzz are drop C, drop C#, any A note, and...
There is something resonating with that note frquency. Often the grille or wiring inside will rattle at certain frequencies. You need a sustained source of these frequencies to find what is causing the noise.
Aug 25, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
Will a MP3/iPod/CD player play through a Fender Frontman 65 or 212 "Power In" input jack?
The power amp input jack takes "line level" input BUT is monaural (single channel). The output of an ipod is Stereo. Hence you would have to "mix" the two channels before connecting to the Fender. Mixing does NOT mean just tying the two channels together. A minimu thing would be a passive resistive mixer consisting of a resistor from each of the IPOD channels to the common point going to the input of the Fender. Remember if you plug into the Fender power amp input you DISCONNECT the preamp and other circuits and would ONLY hear the IPOD input.
Feb 24, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
My Fender 212R 100W 2x12 Guitar Combo Amplifier keeps on cutting out. The guy I took it to says there is something wrong with the cylinders? I also could have heard that wrong. I honestly don't know much...
You had best get a second opinion! When somebody says "there is something wrong" means they don't really know the details enough to give you an estimate even. If the amp cuts out sharply I would suspect that: 1. Bad volume control 2. Cracked circuit board 3. Bad solder joint on circuit board 4. Bad jack. These are in order from least to most likely.
Jan 25, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
I have a Fender Frontman 212r amp. The problem seems to be when I put the volume upto past 4/10 [40%] The amp gives out an awful crackling sound and power light etc flickers on and off. I have had the map...
When i turn on my 212R it turns on in drive channel. if footswith is plugged in, then it turns on in the clean channel, but after switching in drive it is impossible to switch it back in clean channel. What could be wrong? Swith position doesnt change anything and it seems like switch is OK.
Nov 27, 2010 | Fender Frontman 212R 100W 2x12 Guitar...
I cant get good distortion out of my fender frontman 212R can sombody help me with the settings
Start with everything in the 12 o' clock position. Adjust one thing at a time until it sounds good to you.
Apr 23, 2010 | Fender Frontman 212R 100W 2x12 Guitar...
Open Questions:
See all Fender Frontman 212R 100W 2x12 Guitar Combo Questions
Fender Frontman 212R 100W 2x12 Guitar Combo Amplifier Logo
275 people viewed this question
Top Fender Music Experts
Michial Gueffroy
Virgil Watts
Are you a Fender Music Expert? Answer questions, earn points and help others
