HI there lens error happens because of few reasons. If the lens guide pin damaged then you need to replace the lens. But before that try this & let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't
already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Hi there this is Lens guide pin problem. 99% chacHi there please follow the steps and let me know the result.
already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated e is replacing the lens. but before that try these below.
Reason is lens guide pin damaged & replacing is the final solution. But before that trey these.
Hi Steven its look like Memory card or Lens error. Just try this below and let me know the result.
Connect you camera to the computer using the USB cable. It will be shown as a removable drive(If the autorun is enabled windows should list the option to transfer pictures.Choose this option if it does so). Open the drive and and transfer the pictures to your computer.
I hope it may be a ' lens error'.if it means u can try this at once..
Fix #1: Remove the batteries from the camera, wait a few
minutes. Put a fresh set of batteries back in (preferably rechargeable
NiMH 2500mah or better) and turn the camera on.
Fix #2: Remove the batteries, then remove the memory
card. Then install the new batteries, when you turn it on it should
come back to life. Error E30 means you don't have a memory card
installed, so turn it off, slip in the memory card and turn it on one
last time.
